Old 02-24-2020, 07:54 AM
Tankerpilot75 Tankerpilot75 is offline
Default Engine oil heater question
Last year I installed a Reiff Oil Heater on my IO-360. Of course the winter this year is warmer than normal it seems. However my question is the same. Should the sump heater be left plugged in when left in the hangar using the Reiff thermostat to regulate oil temperature? What are the pros and cons?
Iíve discussed this question with several pilots at my airport and their responses go both ways. Iíve noticed when itís left plugged in with full time power the oil is consistently warm (not hot) and the engine compartment feels around 60 to 65 degrees. When I use a wall plug purchased from Ace Hardware that activates only when ambient temperatures drops below 35 degrees, Iíve noticed the oil temperature is significantly lower and the engine compartment reflects ambient temperatures. I assume the temperature controlled wall plug results in more temperature cycles than just leaving it powered full time (therefore I assume greater potential for moisture from condensation).
Wifi activated control is not an option. No cellular access in hangar areas and very poor access at airport.
Jim Harris, 2008 RV7A, 2nd owner, N523RM
Superior XPIO-360, Hartzel CS prop, Older Aerotronics panel with Dual GRT Horizon WS, EIS, Garmin 340, 335 ads-b out, Dual 430s (non-WAAS), TruTrak 385 A/P w/auto level, Electric trim, Tosten 6 button Military Grips, FlightBox wired to WS, Dynon D10A w/battery backup, 406 MHz ELT. Custom Interior, Great POH!
Retired - Living the dream - going broke!
Old 02-24-2020, 08:10 AM
Carl Froehlich's Avatar
Do a search, there should be some lengthy discussions on this topic.
I would never leave sump heaters on, with or without a remote temperature controller. The heaters do exactly what they say, heat the sump. The now warm oil will give off whatever moisture it may have and that moisture will plate out on the cold engine parts, like your cam. If you donít soon run the engine the moisture will do what it does. Not what you want.
If you also have the ring cylinder heating elements this problem is mitigated somewhat, but not enough for me.
The standard process is to get to the hangar a little early, plug in the heaters, do all the stuff you need, go get a cup of coffee, then come back and fly.
Old 02-24-2020, 08:43 AM
BH1166 BH1166 is offline
Default Crazy simple and cheap
$18 Walmart heater, 4x6 floor HVAC vent, aluminum tape, rigid/flex ducting 4”, timer and extension cord. I set timer to come on at 5am, show up at airport at 7am...oil and chts 60 +.
Butch
RV6A Purchased N72TX
2020 Dues Paid
Old 02-24-2020, 08:50 AM
Mark Dickens's Avatar
As long as you're using multi-grade oil and it's not Minnesota cold out, you shouldn't have a problem with the oil flowing well at start up. IMO, the issue is more of a cylinder temp issue because of the potential of scuffing at start up. I'd hypothesize that you could leave cylinder band heaters on full time (with no sump heat on) and address much of the cold start issue while avoiding the condensation problem. Just a hypothesis though.
RV-8 #81077 Super Slow Build
Dynon Skyview HDX, Titan IOX-370, Dual P-Mags, AFP FM200A FI, Whirlwind 200RV CS Prop
First Flight 11/20/2016
www.marksrv8.com
Old 02-24-2020, 10:53 AM
Bcone1381 Bcone1381 is offline
Think of a cold glass of water on a warm summer day. Moisture collects on the outside of the cold glass.
Dis-similar temps will result in the engine when you plug in your engine heater. Warmer temps will be near the heat source, colder temps will exist further out. If the heat is left on all winter, then places where the temp/dew point match in the engine are susceptible to collecting moisture like your glass of water all winter long and rust.
A metal prop is a cold sink and will cause the front of the crank to be cold. A constant speed prop may get moisture collecting in its hub.
So these are problems to over come or turn it on before flight. There are solutions to turn on the pre-heater via a cell phone connection before going to the airport.
Old 02-24-2020, 10:59 AM
10builder's Avatar
10builder 10builder is offline
I recall a recent discussion (Superior webinar maybe) regarding the cylinder band heaters causing rust to appear in a ring shape internally on the cylinders. No indications of short or extended usage, but just an observation.
Brian S.
Arrington, TN
SPA Panther N87XP
RV-10 N104BS (Sold)
2020 VAF donation cheerfully submitted!
Old 02-24-2020, 11:27 AM
N941WR's Avatar
N941WR N941WR is offline
I spoke to Allen Barrett about leaving an engine heater on all the time and he absolutely not. As pointed out above, they cause condensation, which causes internal rust.
Can you get to the hangar early, turn on your heater, and go for breakfast while your engine warms up?
See this Lycoming document for cold weather operations.
That Lycoming document states:
Originally Posted by Lycoming
... For most Lycoming models, preheat should be applied anytime temperatures are at 10˚ F or lower. The exception to this rule is the 76 series models that include the O-320-H, and the O/LO-360-E. These engines should be preheated when temperatures are below 20˚ F...
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 02-24-2020, 11:43 AM
airguy's Avatar
airguy airguy is offline
I'll plug mine in the night before sometimes, but don't just leave it on all the time.
Greg Niehues - PPSEL, IFR, Repairman Cert.
Garden City, TX VAF 2020 dues paid
N16GN flying 560 hrs and counting!
Built an off-plan 9A with too much fuel and too much HP. Should drop dead any minute now.
Old 02-24-2020, 11:57 AM
Default Consensus
Okay. Iíll unplug!
Old 02-24-2020, 12:09 PM
Sam Buchanan's Avatar
been here awhile
My sump heater runs 24/7 four months of the year, CHT and oil temps above 80*F all the time....the RV thinks it is in Florida for the winter. Nineteen years since overhaul on the heater, no signs of rust.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
