Old 12-28-2019, 04:44 PM
Default Only the 9 can do this
Wichita full tanks, 36 gal
Cincy travel 3:43 hr, 610 nm, 20 kt tailwind
then local flights:
local flight 1
local flight 2
local flight 3
and still 9.6 gal in the tanks.
that means all of that flying on 26.4 gallons.
Three Cheers for the 9!
RV-9A, Tip-up, Superior O-320, roller lifters, 160HP, WW 200RV, dual impulse slick mags, oil pressure = 65 psi, EGT = 1300F, flight hours = 800+ for all
www.rvplasticparts.com
Old 12-28-2019, 07:24 PM
crabandy crabandy is offline
No doubt the 9 wing beats it for high XC, but KOKB (Oceanside, Ca) to KAPA (Denver, Co) and a go around and diversion to KBJC (+737 miles) in my 7 on less than 29 gallons ainít bad. I did have more like 30+ tailwind avg for the leg. I almost built a 9 twice before I settled on the 7, you canít go wrong with either!
RV 7 400 hours and counting
19 donation done
Old 12-28-2019, 08:46 PM
I burned over 80 gallons per day couple times. My buddy with his souped 7 can barely finish 40 over the weekend. Go figure which airframe burns less
Old 12-28-2019, 08:51 PM
my neighbor with his twin Baron almost fell over when he saw the fuel gauge on the truck, 26.4 total.
