Old 01-13-2018, 08:08 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Default Tubes
Originally Posted by Saville View Post
Maybe someday someone will design a circuit that is imbedded into the tubes which measures the pressure and transmits it out.
Should be possible now.
I would switch to tubeless tires if I could get a system like my F-150 has..
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1150+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 01-21-2018, 04:26 AM
maniago's Avatar
maniago maniago is offline
Go no/go valve stem gauge? $5? Yeah....wheelpants. But hey, plexiglass wheel pants would fix that!
https://www.walmart.com/ip/MWGear-GL...4-Bar-4-Pieces
Mani
MustangII (FoldingWing) "Finishing up": IO360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,MiniX,EIS,480,327,240,SL30,Navworx; SteamAlt,AS,VSI,wet compass
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Jan2019
Old 01-21-2018, 10:17 AM
Default speaking of tubeless...
I recently restored a prehistoric Kolb Twinstar Mk I. The project came with a new set of spun aluminum one piece 6x6 wheels & brakes; the rims are shaped much like car wheels with smaller diameter center area to allow mounting the tire the same way a car tire is mounted. A friend scrounged a discarded pair of 6x6 Airhawks off a Citabria for me. (More or less 'tundra' on the Twinstar...) I mounted them without the tubes, aired them up, and there's no sign of them losing air over the last 6 months.
The mating surfaces of Cleveland wheels are pretty smooth/consistent; I wonder what would happen if they were assembled with a little gasket sealant...
Charlie
Old 02-19-2018, 12:54 PM
AK4x4's Avatar
AK4x4 AK4x4 is offline
Default tubeless wheels
Both Grove, http://groveaircraft.com/65-10.html, and Beringer, http://www.beringer-aero.com/en/prod...-brakes-14.htm, produce tubeless wheels. Many of the aircraft tires are rated for tubeless applications.
The valve stems of these tubeless wheels are metal. hope this helps. Russ
Russell Brown
A&P/IA
"Happiness may never be sensibly pursued as an end in itself, because happiness is the by-product of achievement." -- Northcote Parkinson (paraphrase)
Wasilla, Alaska
