Old 01-11-2018, 11:19 AM
RV7A Flyer's Avatar
RV7A Flyer RV7A Flyer is offline
Originally Posted by bpattonsoa View Post
I did not say I have to remove pants to air the tires. The -10 has huge pants and with a straight stem as provided in the kit, you have to remove the front half to add air. I don't.
My pants have a 1 1/2" snap in cover, the tires a big red paint dot that lines up the stem with the opening when it is down, the tube is a 45 degree stem so it is horizontal, and an inflator with a 10" long extension and it is still a pita to add air.
I just want to monitor the inflation pressure easily so I can add air at my leisure, not under time pressure!
Which I agree would be a nice thing to be able to do.
Unfortunately, as on most all forums, if you ask about X, you'll get all sorts of responses that do everything but actually answer your question. These threads are filled with examples.
2019 Dues paid!
Old 01-11-2018, 12:17 PM
Default Car?
I was wondering if the toyota TPS system can be made to work? The coding cant be that tough and the sensors are small enough
John S
Dues paid 2019, worth every penny
Fuselage 30%
Old 01-11-2018, 12:42 PM
Larco Larco is offline
As car tires are tubeless the sensors are inside the tire, where these are on the outside because of tubes being used. It will be interesting to hear how these motorcycle types work out.
Old 01-11-2018, 02:16 PM
BillL BillL is offline
Originally Posted by Climb3zero View Post
I just ordered this yesterday to see if it would work.
https://www.ebay.com/itm/162705306876
The caps look huge and I have my doubts but I'm going for it anyway. I will let you know as soon as I see the results. Ed
Interested to hear how they work. The older tech only activated when the wheels were in motion, so a leak-in-flight- was not detectable.
Please post a pirep when tested.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Repairman 11-15-18
Instrument Currency 12-17-18
Shrunken Exit = ??
No Photo? => PM me.
Old 01-11-2018, 03:23 PM
RV7A Flyer's Avatar
I'd be not very concerned with that capability...it's more the ability to monitor the pressure on a sort of continuous basis, over weeks/months, and note if it's low enough to do whatever it takes to access the tire and fill it up.
2019 Dues paid!
Old 01-11-2018, 08:23 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Default wheel chocks
I realize that the OP wants to monitor the tire pressure from his bedroom, but I thought I'd throw this out anyway. A pair of properly or accidentally constructed U shaped wheel chocks act like a tire pressure gauge. Mine are PVC pipe. If they "hang" when you are removing them, then it is time to add air.
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
Old 01-12-2018, 09:08 AM
Climb3zero Climb3zero is offline
I got the Accutire pressure system and opened it up. Looks good and is easy to set up. It is not installed on the plane yet as I am worried about the weight of the caps that screw onto the stem of the tube. These things are pretty big measuring 1 inch tall with the diameter of a quarter. The G's that these things will put on the stems going from zero to 70 mph in an instant and then rolling down the runway at high small tire speeds has me concerned that I will just eventually shear the stems off. The kit comes with lead weights to help balance the tire if needed.
I think I will just put these on my motorcycle and for now wait until we discover something a little better for the plane....waiting patiently for that day!!!
Meanwhile I better get to church, gotta get married today!...again.
Old 01-12-2018, 09:19 AM
sirlegin's Avatar
sirlegin sirlegin is offline
http://www.aircraftspruce.com/catalo...ickkey=4809133
Nigel
RV9A-N113SQ
52F
Old 01-13-2018, 01:00 AM
dlomheim dlomheim is offline
Default Motorcycle TPS
I'm curious how you will: "...just program factory tire pressure into the caps and place caps on valve stems." Do they send you an operational program to download to your computer, and then you have to plug the sensor into your computer to receive the programing? Please update the list with what you find out / discover. thx.
Doug
RV-3A sold
RV-9A Mazda 13B / FWF (on hold)
Old 01-13-2018, 07:47 AM
Saville's Avatar
Saville Saville is offline
Maybe someday someone will design a circuit that is imbedded into the tubes which measures the pressure and transmits it out.
Should be possible now.
Flying RV-8 N880BC
2019 Dues - happily paid.
