Old 05-24-2018, 08:26 AM
garrys garrys is offline
Default Saint Aviation the BEST
I want to put in a plug for what I consider to be the absolute best avionics shop in Florida, if not in the entire US. Saint Aviation located at X35 Marion County Airport in Dunellon Florida.
My 10 year old RV7A had an older panel which I have been slowly updating. I've got a mixture of different vendor equipment.....Garmin, GRT, TruTrack, etc., and I have used many different avionics shops in the past to install the equipment. Getting all the avionics to play well with each other and speak the same language has been a problem. Each vendor points the finger at the "other guy" and disavows any responsibility for malfunction. Jesse Saint however took a genuine interest in sorting out the issues and exhibited the patience and perseverance to make everything work as it should. What a blessing!!!
Saint Aviation is the holy grail for RV builders/owners, performing all manner of RV maintenance including builder assistance programs as well as airframe and powerplant work. At any given time there are a dozen or so RVs in the shop with 3 or 4 under construction. The shop is clean and organized with every tool ever needed. The team of technicians are highly trained and thoroughly professional....and extremely polite and helpful. They are also experts in RVs. My experience with Saint Aviation has been the best ever! If anyone ever needs any help with their plane, that's the place to go!
Old 06-03-2018, 07:53 PM
Driftdown Driftdown is offline
This is a shout out for Jesse Saint, at Saint Aviation, Marion Co. Airport, Florida (X35).
I highly recommend Jesse for Dynon Skyview installation and servicing.
He is very sharp on Skyview and does a superb job, installing/replacing Dynon Skyview components and specializes in troubleshooting.
Being way down here in Florida, Jesse was recommended to me by Dynon Customer Support. Jesse and his assistant, Philip, solved my Skyview anomaly in short order, which had puzzled myself, as well as the tech's up in Seattle. Thank goodness they referred me to him.
Additionally, Jesse's hourly rate for labor was extremely reasonable, as compared with other outfits in Florida. I have used Saint Aviation several times now and could not be more pleased.
Contact Information:
Jesse Saint
jesse@saintaviation.com
Phone: 352-427-0285
Fax: 815-377-3694
10575 SW 147th Circle
Dunnellon, FL 34432
Old 06-03-2018, 11:16 PM
Vansconvert Vansconvert is offline
I could not agree with you more. Very knowledgeable, professional, and personable.
RV-7A
IO-360 Hartzell CSP
Purchased
Old 06-04-2018, 06:23 PM
f14av8r's Avatar
f14av8r f14av8r is offline
Default Jesse's the Best
It really is hard to describe what a great resource Jesse and Saint Aviation are for the RV community. If you are anywhere close to North Central Florida, you should seriously consider using Jesse for ANYTHING you might need done on your RV. Seriously, look no further.
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (flying)
Flying an A320 to pay the bills
Exempt and gladly donating anyway - Current through Jan 2019
