Go Back   VAF Forums > Avionics / Interiors / Fiberglass > APRS Tracking
Old 11-15-2016, 12:51 PM
swordtail swordtail is offline
what equipment are you using for tracking? A handheld or mobile mounted in the plane?
WB3CKV
Old 11-15-2016, 03:10 PM
Sam Buchanan's Avatar
Sam Buchanan Sam Buchanan is online now
been here awhile
Originally Posted by TruTrakAndrew View Post
I just decided that if I was going to do it, then I might as well do it. I have been having fun with it already. Once I finish the Extra, it will be time to learn CW.
CW....that's pretty hard core.....sounds like you are going to be a "real" ham....
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 01-06-2017, 06:35 AM
JPalese's Avatar
JPalese JPalese is offline
Default CW
I have been a ham since 1968, starting as a Novice and upgrading class by class to Extra. I learned CW so long ago that I am having to relearn it at speeds above 7 or 8 wpm.
FWIW what i have found to be most helpful relearning the code is FLDigi with FLWkey. I can listen to the CW signal and while decoding in my head see it decoded on the computer screen in front of me. I have the option of using either my key or the keyboard to respond.
My 93 y/o Dad did crossword puzzles his entire life to keep his mind sharp - I think crosswords suck, so opted to relearn the original binary language and then use it regularly for mind sharpening as I age.
73
John
PS DR please add my call sign to the airplane tracking list. Haven't decided for certain, but am considering a -12 suffix for the RV12 and -7 suffix for the RV-7 . . . Any thoughts? [ed. Wilco! Can you give me your N-number and/or Ham ID? v/r,dr]
John Palese
1) AAL Captain & Check Airman (ret)
2) USAF LtCol & Command Pilot (ret)
Active:
1) ATP / CFII ASME
2) Adjunct Professor-Aviation Science
3) MKE FSDO FAAST Lead Rep & Remedial Trainer.
RV-12 Transition Training, Rental & Instruction.
RV-6/6A, RV-7/7A, RV-9/9A transition training
RV-7 Transition Training LODA.
Drone Detection & Counter-measures
DE WB9JPH
<IXOYE><
www.facebook.com/rv12wi
www.facebook.com/rv7wi
http://www.terravigilis.com
Old 02-14-2017, 03:46 PM
24Golf's Avatar
24Golf 24Golf is offline
Talking Sign Me up
Been a ham since 1984... finally on APRS with the RV9. Put me on the list:
http://airprs.com/#/tab/logbook/call/N2724G
Paul & Beth Duff
N2724G - RV9A - 1000+ Hours
Vans # 91642
FLYING 10.15.2010
BLOG: http://2flyamerica.com/
Old 02-23-2017, 08:06 PM
Dubuque RV Dubuque RV is offline
Default ARPS tracker add to list
Doug, please add N955DQ, an RV-10 to the list. KF4UIR. Thanks. Just have the tracker put together not yet installed.
