Old 05-15-2017, 07:01 PM
bruceh's Avatar
bruceh bruceh is offline
I got my airplane all put back together after getting painted, and now the APRS is no longer working. The Micro Trac is in the left wing tip, and has always performed great. My first thought was I misconnected something during reassembly, so I took off the wing tip again, and everything was fine. GPS puck stuck down on the bottom of the wingtip with some velcro. The J-pole antenna also in place and connected tightly to the unit. The GPS and power is connected and I get the usual red/green LED indications that it is online, and after a few minutes a steady green LED indicates that the GPS has a position lock.
I put the wing tip back on and flew around yesterday, but still no tracks getting broadcast!
Could the paint on the wing tips be blocking the GPS? It does have some amount of metal flake in the paint, but it certainly isn't what I think would be extreme enough to be a problem.
Does anyone here have any other advice on troubleshooting this issue?
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 05-15-2017, 07:29 PM
Bill Boyd's Avatar
Default maybe
metallics in paint are blocking the VHF signal from the Tx rather than the GPS reception. Check VSWR after painting? Might not be easy to do inside the tip, but it's a free suggestion
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 05-16-2017, 03:31 AM
humptybump's Avatar
Where did you perform the test flight? If it was sufficiently local, it could be a ground station off-line.
There are a number of plane with metallic paint and trackers so That may not be the [full] problem.
If you know a HAM radio operator and/or can find a radio that will receive 144.39Mhz, you can verify you are transmitting.
Originally Posted by Bill Boyd View Post
he better _be_ a ham operator
Clarification (for smarty people): "find a HAM operator with lots of useful tech toys like 2M portable radios, antenna and transmitter testers, etc.
- Glen, ESVA
Last edited by humptybump : 05-16-2017 at 07:09 AM. Reason: responding to Bill's snarky remark :-)
Old 05-16-2017, 07:00 AM
Bill Boyd's Avatar
Default If he's on APRS
Good point about verifying tx on 144.39 with an HT or other rig, ideally while watching the status LED's on the tracker to be sure it's _your_ data burst you're hearing.
Bill Boyd
Old 05-16-2017, 10:08 AM
bruceh's Avatar
Yes, I'm officially KJ6YRP and I do have a handheld. This weekend I flew up and back from Ramona to Corona, and Ramona to Cable to Long Beach and back. I always have great APRS coverage in the SoCal area.
Bruce Hill
2018 VAF donator
EAA Tech Counselor
Old 05-19-2017, 11:41 AM
bruceh's Avatar
It is back working. I was able to hear the packet bursts from my handheld scanner. Not sure what was the issue during the previous flights. I just opened up the wingtip and made sure all of the connections were OK. Maybe I just had to jiggle the wires a bit?
Bruce Hill
2018 VAF donator
EAA Tech Counselor
Old 05-19-2017, 08:02 PM
Bill Boyd's Avatar
Default that's happened to me before, Bruce.
More than once. Tracker mysteriously inop at a locale/altitude where I've always hit iGates in the past. No sooner than I check connections it starts working on the next leg of the flight.
I suppose all this will become fairly moot once 2020 gets here and we can be tracked all the time by big brother.
Bill Boyd
Old 05-23-2018, 11:18 AM
bruceh's Avatar
Default update
I'm in the middle of doing my annual condition inspection, so the wing tips were off again. I had disconnected my J Pole antenna and put the APRS antenna that I got with the tracker inside the wing tip back several months ago. The changing of the antenna solved the issue I was experiencing with packets not getting heard. I was back to spitting out packets reliably. When I did this change, I just left the J Pole antenna in the wing tip (figuring I might need to use it again if the other antenna wasn't the solution).
I pulled out the J Pole antenna and found this on the end.
I don't recall seeing the conducting wires sticking out of the end before.
Maybe this was shorting and causing the intermittent issues?
I did a Google search on J Pole antenna fabrication with TV antenna wire, and some examples have the wires at the end connected and others say not to connect it. I guess it depends on how long the wire is to match the wavelengths of the transmitter. Obviously, this model left them disconnected.
So a question for Pete: Can I just cut off the wires extending from the tip? I have a picture of the J Pole antenna when I originally installed it, but zooming in is a bit blurry. I don't see the wires poking out more than a tiny bit. I'm just wondering how the wires started migrating out of the insulator plastic covering (vibration? heating/cooling?).
Has anyone else seen this happen before?
Bruce Hill
2018 VAF donator
EAA Tech Counselor
Last edited by rv7boy : 05-23-2018 at 12:29 PM. Reason: "bump" is a four letter word!
Old 05-23-2018, 01:29 PM
VHS VHS is offline
Default Antenna
Bruce,
Let me know if your antenna is not repairable, I can dig up one of our V6 ( Center-fed, 1/2 Wave dipole) which is a bit shorter and will get a bit more ERP out of your Micro-Trak. You can E-Mail me directly: Vhs18092@aol.com.
73,
Allen AF6OF
VHS/BYONICS
Old 05-23-2018, 02:13 PM
gnuse's Avatar
gnuse gnuse is offline
The V6 made a big difference in my RV-8 wingtip installation. Thanks to Allen for getting me to change from what you were using. He is very, very good at keeping you up and running IMHO.
George
"God does not deduct from one's time on earth that which is spent in the air."
