Old 08-16-2015, 01:03 PM
Default APRS stopped working
Hi folks:
After a flight down to Red Wing a couple of weeks ago, my APRS suddenly stopped squawking me.
I've noticed some gaps in the track just prior to that, Oshkosh for example.
But nothing since that Red Wing flight.
We flew through a fair amount of rain on the way back from Cleveland a couple of months ago. And there was a long gap through Indiana.
I took the wingtip off today and verfied that the unit is getting a signal from the GPS -- steady green light -- and that it is transmitting -- red light and a packet burst on the scanner in the hangar.
The antenna was twisted in a few spots as the old Gorilla tape let go but I replaced it all and went for a flight today.
Nothing.
What steps should I take to diagnose this problem?
Bob Collins
St. Paul, MN.
Almost ready to start the RV-12iS finishing kit. 480 hours in.
Builder log
Old 08-16-2015, 02:40 PM
Joe Joe is offline
Bob,
Good idea checking the antenna/RF situation but that is definitely not the problem as evidenced by your recent raw packets on aprs.fi. Plenty of packets but alas, not a single legitimate position report in the last 149 packets on August 15. I've never seen anything like this.
Couple of possibilities come to mind: could your GPS settings have been changed so it's no longer outputting $GPGGA or $GPRMC sentences or some other GPS-related malady? (I'm not sure if the steady green LED means the GPS is sending good sentences or only that it has acquired satellites.)
Your TinyTrak3 has switch-selectable primary and secondary operating parameters. Most people skip the switch and used the default (primary) but is it possible you've switched to the secondary parameters and they aren't programmed properly for position reports?
It would be helpful if you would post a screen capture of your TinyTrak3 configuration screen. Perhaps something seemingly innocuous somehow managed to get checked.
Joe
Joe Dubner
RV-8A
Independence, OR
Old 08-16-2015, 05:45 PM
GPS not likely the culprit, at least in configuration.I'm using the little GPS puck out there, not feeding from the 296 in the cabin.
But, actually I'm using an old Micro Track (since discontinued)
I'll have to pull the unit, rig up the cable and see what the current configuration is.
Since we flew through so much rain coming back from Cleveland, I'm kinda wondering if there's any possibility a static electricity buildup might've had some kind of impact. Of course that was before the Red Wing flight.
I'm inclined to just upgrade the system.
Bob Collins
St. Paul, MN.
Builder log
Old 08-16-2015, 09:50 PM
JohnInReno's Avatar
JohnInReno JohnInReno is offline
Originally Posted by LettersFromFlyoverCountry View Post
Hi folks:
I have noticed gaps recently:
http://aprs.fi/#!mt=roadmap&z=11&cal...600&tail=21600
Nevada is kind of spars but not that much!
Tiny track with it's own GPS.
John Morgensen
RV-9A N946PM 600+ hours since 2013
Nevada/Arizona
Old 08-17-2015, 12:24 AM
petehowell's Avatar
Default Position Info
Bob,
I looks like your position info is not coming thru. Packets are there on the web, but no data to tell them where to plot it.
If you look at some on my raw data, you can see the position info:
2015-08-11 16:42:36 CDT: KD0CVN-1>APOT21,WIDE2-1,qAR,W0YC-5:!4434.37N/09230.43W'290/129/A=002427-018807.9V 74F
2015-08-11 16:44:21 CDT: KD0CVN-1>APOT21,WIDE2-1,qAR,N9XH-4:!4436.16N/09234.66W'302/119/A=002514+006607.8V 74F
2015-08-11 16:44:57 CDT: KD0CVN-1>APOT21,WIDE2-1,qAR,N0AGI:!4436.84N/09235.95W'314/112/A=002554+005507.9V 75F
Might be a bad connection from the GPS to the microtrak. Give me a call and we can talk thru it.
Pete
Amateur Plane - RV-9A N789PH - 2050+ Hrs
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 08-17-2015, 06:28 AM
I hadn't seen the packet data before. That certainly answers a lot of questions.
Connections were solid between the gps and MT so I've ordered a new one and I'll swap it out.
Bob Collins
St. Paul, MN.
Builder log
Old 08-17-2015, 10:18 AM
NovaBandit's Avatar
NovaBandit NovaBandit is offline
I think your APRS just wanted to stop for some drinks at Muddy Waters in Prescott!
Ed Kranz
RV-10 N829EC - Flying
First Flight: 8/29/15
KSGS - Fleming Field, South Saint Paul, Minnesota
YouTube.com/GoodPlaneLiving
-- Build Timelapse and Travel Videos . . GoodPlaneLiving.com -- Build and Travel Blog
Old 08-21-2015, 04:19 PM
Pete et al. I swapped out the GPS with a new GPS5 from Byonics. I got a flashing blue LED on the GPS5, signalling a link with the satellites, and I've got a steady green LED on the MicroTrak, signalling it's getting GPS data. Of course I had a steady green with the old GPS too, so there you go.
I haven't taken it up yet to see if it can hit a repeater and send good data.
Bob Collins
St. Paul, MN.
Builder log
Old 08-21-2015, 09:13 PM
mtnclimber mtnclimber is online now
At about that same time, I had a flight from Northern AZ to Colorado, where packets were sent, but no GPS position. Flew again last week and worked perfectly.
My guess would be a temporary problem on the APRS server. GPS seemed to be normal on the EFIS, or I'd suspect a gps outage.
Old 08-21-2015, 09:16 PM
petehowell's Avatar
HI Bob,
we might want to program the microtrak to not use Mic-e compression, too. I can do that for you with my old laptop.
Send me a message if you are coming to KANE for the AOPA thing.
Pete
St. Paul, MN
