Go Back   VAF Forums > Avionics / Interiors / Fiberglass > APRS Tracking
Old 04-24-2014, 10:14 PM
N941WR's Avatar
N941WR N941WR is offline
Default To APRS or not to APRS? That is the question.
I have been on the fence for a long time with regard to installing a device in the plane to allow anyone to track my flights. That has changed over the past few weeks as a friend and neighbor disappeared in the swamps north of Zephyerhills, FL on the 5th while flying his Sonex.
They still have not located him or his plane and I'm positive that had he put an APRS unit on board, he would have been found by now and possibly saved.
Thus, I start my quest for APRS knowledge.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-25-2014, 12:03 AM
jclark jclark is offline
Default Just Do It! :-)
Bill,
The peace of mind is significant, not just for you but those who care about you. You can have an ON/OFF switch for those cases where you just don't want to clog up the system while beat up the pattern or when you are flying along with others.
I have used the system for years and now that I am having problems with my installation, at times I feel "naked".
Give a call some time and I will share more opinions.
James
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
Old 04-25-2014, 12:18 AM
tim2542 tim2542 is offline
Default Good coverage
I've been amazed at the coverage, even while crossing some of the most desolate places in the country, like Northern Nv, Wy, SD etc. Always have have a good trail show up.
And my wife appreciates being able to follow me on trips from her phone.
Tim
Old 04-25-2014, 12:49 AM
rv7boy's Avatar
rv7boy rv7boy is offline
Forum Peruser
Default Get Some kind of Tracker
Yes, Bill, whether it's an APRS or a satellite tracker or what have you, if you can get a reliable unit in your plane, do so. I bought a Byonics Micro-Trak RTG FA in 2011, and it has been very reliable for me. When I fly animal rescue flights I rely on it plus a VFR flight plan to help my family plus the search teams know where I've been.
As for the Ham license, in my opinion, anyone who can pass an FAA private pilot exam should be able, after proper study, to pass the FCC Amateur Radio Technician exam.
Good luck with whatever you decide, but just Do It!
Don Hull
RV-7 Wings
KDCU Pryor Field
Pilots'n Paws Pilot
N79599/APRS Automatic Position Reporting System
“Certainly, travel is more than the seeing of sights;
it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
"It should be added that the sublime beauty of the facture brings within the realm of discourse the substructure of critical thinking. " -using Doug's Art Critique jargon link and my birthday, I get this!
Old 04-25-2014, 04:42 AM
rleffler's Avatar
rleffler rleffler is offline
I agree with Don. The ham test is easily passed with a few hours of study by anyone that has built their aircraft or is used to taking certification tests.
I've trained my family if I'm over due to check aprs to see where I'm at if not back by a predetermined time. While anyone can track me, I really don't care. I have ADSB-Out, so the Feds already know where I am.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 04-25-2014, 05:50 AM
Mark Dickens's Avatar
I've installed a Byonics MicroTrak RTG-FA...easy to install and if you have avionics that can output basic NMEA sentences, you can integrate the RTG with that and avoid mounting another GPS antenna. I've integrated mine with my SkyView system. I've also put the unit on a power switch so I can control when I'm "tracking".
RV-8 #81077 Super Slow Build
Titan IOX-370, Dual P-Mags, AFP FM200A FI, Sensenich GA Prop
First Flight 11/20/2016
www.marksrv8.com
Old 04-25-2014, 06:09 AM
humptybump's Avatar
There are a few very easy ways to add APRS to an airplane. The Amateur Radio Technician license can be studied over a few evenings.
Now here is the twist - it's called an "amateur license" for a reason. There are no guarantees. That said, I've not found many failure points in my three years of using a tracker.
My feeling is APRS is better than no APRS but if you are looking for safety, a satellite based system such as a PLB may be your choice since it works on the ground whereas APRS (as configured for flight) often will not. I also think ADSB-out will add another layer.
I enjoy having a tracker. My family and friends "check in" often. For cross country flights and most weekend trips I tell people at both ends of my route and they "watch over me".
It also helps with timing the "pick me up at the airport".
There are lots of reasons to enjoy APRS but remember, it's only as good as our infrastructure.
Disclaimer: I'm the guy distributing iGates through VAF members
- Glen, ESVA
Old 04-25-2014, 06:38 AM
Brantel's Avatar
Brantel Brantel is offline
Love my tracker!
Brantel (Brian Chesteen),
Check out my RV-10 builder's BLOG
RV-10, #41942, N?????, Working on Emp/Tail Cone
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 04-25-2014, 07:12 AM
bsacks05's Avatar
bsacks05 bsacks05 is offline
My installation cost less then $200, HAM included. Why not?
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 04-25-2014, 07:57 AM
Greg Arehart's Avatar
Greg Arehart Greg Arehart is offline
Bill,
Invaluable for tracking as has already been said. However, make sure that it is configured properly for wherever you are flying. With the "normal" configuration, mine would "drop out" when over the remote areas of Nevada because it couldn't find any primary stations within reach. This first time this happened (and I was very new to the APRS) Julia was really worried that I had disappeared and in trouble. Once reconfigured to hit secondary stations, I've not had any issues and have even gotten decent signals out in some very remote locations (i.e., east-central Yukon!). Even so, there are some places where no repeaters exist (northern BC along the coast is one) where you can't get a signal out. So I always also carry a PLB as well.
For most uses, as already noted by others here, it is a really good aid for a lot of reasons. Link to the map of North American repeaters:
http://wa8lmf.net/APRSmaps/NorthAmericaLarge.htm
Greg
Greg Arehart
RV-9B (Big tires) Tipup @AJZ or CYSQ
N 7965A
