Old 10-22-2013, 08:34 AM
Kevin Horton's Avatar
Kevin Horton Kevin Horton is offline
Question J Pole Antenna in Wing Tip with Archer Antenna?
I'm planning to install an APRS system in our RV-8. I'd like to use an internal antenna, but I've got a Bob Archer NAV antenna in one wing tip, and an Archer COM antenna in the other tip.
I'd appreciate any experience from others who have installed a Pete Howell J-Pole antenna in a wing tip with an Archer antenna. Was there any interference from the APRS onto the NAV or COM?
I'm thinking the best chance of success is to put the J-Pole in the side with the NAV antenna, as the NAV antenna sits flat on the top of the wing tip.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 05-10-2015, 06:29 PM
N15JB N15JB is offline
Resurrecting this old thread, because after searching the entire aprs section I never found a definitive answer to Kevin's question.
I have a Bob Archer nav antenna in each wingtip of my -10. I would like to put a J-pole antenna for my Byonics MicroTrak RTG in one wingtip. Can I expect good performance from my nav and the tracker with this arrangement? If not, which external antenna has the blessing from the cognoscenti?
Jim Berry
