https://www.ntsb.gov/_layouts/ntsb.aviation/brief.aspx?ev_id=20200613X70924
If what is written here turns out to be true this sure looks tragically preventable.
14 CFR Part 91: General Aviation
Accident occurred Saturday, June 13, 2020 in Mandan, ND
Aircraft: Vans RV8, registration: N836JC
Injuries: 1 Fatal.
This is preliminary information, subject to change, and may contain errors. Any errors in this report will be corrected when the final report has been completed. NTSB investigators may not have traveled in support of this investigation and used data provided by various sources to prepare this aircraft accident report.
On June 13, 2020, about 1400 central daylight time, a Vans RV8 airplane, N836JC, was destroyed when it was involved in an accident near Mandan, North Dakota. The pilot sustained fatal injuries. The airplane was operated as a Title 14 Code of Federal Regulations Part 91 personal flight.
According to initial information from the Federal Aviation Administration (FAA), a witness observed the airplane on the ramp prior to the flight and advised the pilot that the rear seat belt was securing the rear control stick. The pilot subsequently departed in the airplane on runway 13 at the Mandan Municipal Airport (Y19), near Mandan, North Dakota. The takeoff was a 3-point takeoff and the airplane subsequently had a steep climb. The airplane descended, impacted terrain, and a ground fire occurred.
