Old 08-19-2019, 01:04 PM
von_flyer von_flyer is offline
Default GTR 200 PTT wiring question
Can the Garmin GTR 200 be wired so that a panel mounted PTT switch (one for pilot and one for co-pilot) is connected to the PTT input and ALSO be able to use an inline PTT (Telex type or similar) connected between the headset mic and the mic jack?
If so, is a diagram of that available? The manual shows the PTT connections for a panel mounted switch, maybe I am missing something obvious.
Thanks!
John von Linsowe
Michigan
Cessna 140
Old 08-19-2019, 02:25 PM
fl-mike's Avatar
fl-mike fl-mike is offline
Yes, should be no problem. In this case, a ground is a ground. See Note 7 in Appendix D.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS, L3 Lynx NGT-9000
N164WM
N184WM reserved (RV-8)....finishing kit in progress. Titan IOX-370
Old 08-19-2019, 02:54 PM
Tom023 Tom023 is online now
One of the two user programmable buttons on the GTR 200 can be set as a PTT also if that helps.
RV14A #140083
Flying! 8/12/19
2019 Donation
Old 08-19-2019, 03:59 PM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Thanks!
Hello John,
As Mike says, guidance is provided in Appendix D of the Rev. L GTR 200 Installation Manual to accomplish this, but if this is not clear, just email us and we will provide a marked up diagram.
We used to always show the PTT wiring being connected to the tip of the MIC jack in case someone wanted to use a hand MIC, but since so few do, we prefer to keep the PTT wiring totally separate from the MIC wiring as is presently shown in the manual.
Steve
Garmin G3X Support
g3xpert@garmin.com
1-866-854-8433 - 7 to 7 Central Time M to F
Please email us for support instead of using Private Messaging due to the limitations of the latter.
