Old 01-27-2018, 03:13 PM
Lynnb's Avatar
Lynnb Lynnb is offline
Default Cabin Top/Windows/Motor Does the Order Matter
I was just curious if the engine could be hung and worked on before the Cabin top was installed?
If the cabin top is installed, does the front windshield need to be installed before the engine is hung?
I'm still working on my cabin top, doing some fiberglass, planning some painting etc and was thinking I could start some of the baffling and cowling work in my down time while stuff is curing/drying.
Lynn
RV-10 in Process
Old 01-27-2018, 04:15 PM
From an engineering perspective, there's nothing to stop you from doing what you propose. I would install the vertical hinges along the sides of the firewall before you hang the engine. That will firm up the front structure for the 400 lb+ engine.
Also, remember that once you put the airplane on its gear, you absolutely will need a ladder to work on the cabin top - at least the upper portion. That would be a show stopper for me. I don't need/want that inconvenience.
Sez the guy who just "finished" the cabin top, doors, and windows, and put the airplane on its gear a week ago today...
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 01-27-2018, 04:19 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is online now
Donít underestimate the time needed for cabin top, doors and glass. Consider the downside of taking the nice pickled engine out of the crate for such an extended period.
The other consideration is all the glass dust you will generate from sanding. No need to trash the engine with that.
Old 01-27-2018, 04:33 PM
rocketman1988 rocketman1988 is online now
Default Yeah, what he said^^^^^
What he said!
Bob
Aerospace Engineer '88
Structure - 90% Done
Cabin Top - Aaarrghhh...
Doors - Done
On Gear
290 HP Barrett Hung
Dues Paid 2017,...Thanks DR+
Old 01-27-2018, 06:07 PM
Bill Boyd's Avatar
Default Perfect segue opportunity here:
I'm tired of working on wingtip mounting hinges (got all 4 hinge pins in place and I'm declaring victory for now).
Have firewall insulation and SS foil ready to mount and seal with FireBarrier 2000 or whatever it's called. Before covering the firewall with fibrefrax and foil, I need to first rivet the forward top ribs to the firewall with 1/8" flush rivets, and the plans say to attach the top skin to them (in a very specific riveting pattern) before attaching the subassembly to the firewall.
I was going to rivet the ribs to the upper part of the firewall and put the top skin on later, after all necessary holes cut for avionics/wiring. May not have that luxury if the sequence detailed in the plans is critical for some as yet unappreciated reason.
I'm probably going Quik-Panel AFS or Dynon. Hopefully there wont be a lot of cabling to do upside down underneath the panel in "the position." Yeah, right. Any advise on what sequence to do this work in? I'm trying to keep the skins forward and aft of the cabin top off as long as possible, but there comes a time you run out of other things to do. I don't own an engine or avionics yet, so the airframe is all I have to expend my energies on.
I'm intermittently sanding and filling the cabin top and leveling/blending same with doors and side skins. Can't finish that work until the skins are all on. Transparencies from Cee Bailey soon, I hope.
Bill Boyd
Hop-Along Aerodrome (12VA)
Old 01-27-2018, 06:54 PM
RV10Pilot RV10Pilot is offline
Lynn,
It will be much easier working on the cabin top, doors and windows when the fuselage is down low. Get all that done prior to putting the plane on its gear. It will save a ,it of work on a step stool or ladder.
Old 01-28-2018, 06:56 AM
Lynnb's Avatar
Thanks for the info. I've actually already fitted the doors and done all the trimming to fit the top, door seals, rivet backing strips etc. I'm just still deciding on interior paint, working on a fiberglass overhead and some of that sort of stuff. I have a bit vertically challenged, that's why I've kept it off the gear for so long.
As always I appreciate the feedback.
Lynn
RV-10 in Process
Old 01-28-2018, 08:35 AM
bluskydreamin bluskydreamin is offline
Default Same thoughts....
Bill. I was thinking the same with riveting the forward fuse structure on and adding the skin later after wiring and sub panel avionics boxes are mounted.
The other models have us do this. I guess it's a trade-off of lying on your back bucking rivets or trying to do the other tasks inverted... Either way we have to pay the Piper
Old 01-28-2018, 09:11 AM
You can build the entire upper forward fuselage (UFF?) structure and NOT rivet it to the fuselage until after your cabin top is attached. If you do it that way, you can set the entire UFF on the bench and do a bunch of your subpanel and panel work on the bench - subpanel cuts, mounting locations for fuseblocks, AHRS units, panel cutting, etc. Then, pull that stuff off, and you can rivet the UFF in place and reinstall all of the bits and pieces. Much easier doing all of that on the bench than trying to do it in the footwell of misery.
The one thing you can't do until the UFF is riveted in place is install the windshield.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
Old 01-28-2018, 10:04 AM
Default Curious...
I am curious, I have pretty much planned out my avionics and I am not seeing many instances of laying in the footwell to do the wiring. Almost everything that is required will be accessible from the cabin. I do have the Aerosport symmetrical panel, so there are three rather large holes to work through.
I am not planning on putting anything between the sub panel and the firewall. Obviously, that area is rather inaccessible at all times. I do see the value of doing a bunch of avionics work prior to riveting the forward section, however, as I do not have my avionics yet, I went ahead and riveted. So far, I have not had to get in the footwell except to rivet the forward section.
I will say that driving some of the rivets from the firewall to the forward section substructure was very challenging as the engine mount is in the way...it's doable but would have been MUCH easier without the mount installed.
So, what task is going to require time in the footwell?
Bob
Doors - Done
On Gear
290 HP Barrett Hung
