Practice Routine for Keeping Skills Sharp?
lndwarrior
I want to go practice today and I was thinking about what skills to work on. I was wondering if someone had worked out an efficient practice routine?
I'm imagining something that would kind of flow together to make the most efficient use of time in the air. Kind of like the type of process that an aerobatic pilot uses for a routine.
It may start with a particular type of takeoff, then some various types of practice during a long climb-out, then at altitude a series of practice routines, then a multi-step descent with various maneuvers during a step down, etc, until landing.
I could put something together myself but sometimes it's nice not to have to figure stuff out when someone already has a plan.
TIA
Gary
When I feel rusty several circuits of the pattern with different types of landings restores confidence in all flight maneuvers. When the pattern work is really sharp, so is everything else because of the different flight parameters required for precise patterns and landings.
practice
I would say make every landing different forget pulling power at the numbers at a certain height learn to adjust to any situation and always make the first turn off.
Bob
.......I'm imagining something that would kind of flow together to make the most efficient use of time in the air. Kind of like the type of process that an aerobatic pilot uses for a routine.......
I'm hoping someone shares there routines. That's a great idea to have a systematic approach similar to aerobatics. Maximum use of our avgas!
Back in the day in Alaska, I didn't have a prescribed routine...except...
Every landing was a spot landing. Not just in "on the line" but also left or right alignment (we mostly didn't have centerline to help us).
Of course keeping our skills up for landing off field was the big incentive but the payoff for airport landings was that making a taxiway turnoff was never in doubt. Practice used to include every manor of wind direction there was. Gusty quartering tailwinds were the most challenging but it can be done and the confidence from having those skills made everyday operations a breeze.
Hope you get some good input for this thread.
-M
in my 1000 hrs of flight time, I don't believe I have ever landed with a gusty quartering tailwind. what's it like? how differently does it behave?
Rusty pilot - way too often!
When I?ve gone a period of time without flying I tend to do the following on the first flight out of my home airport (KRQO) which is uncontrolled (no tower).
1. Start engine, Taxi, Takeoff and Climbout paying close attention to checklist discipline, smooth application of power and airspeed control. I always ask for traffic advisories from OKC approach control on climb out letting them know my intentions.
2. Twenty to thirty minutes in a practice area working on steep turns, power on and power off stalls, and stall recognition/prevention. I try to pay close attention to heading control, stall speeds, altitude lost and smooth recovery. It?s also critically important to constantly visually clear the area and look for emergency recovery sights in case a forced landing.
3. Then it?s time to request some practice instrument approaches from OKC approach control. These are usually done at an airport with an operational tower (KOKC or KPWA). Since I?m usually VFR between 5,000 and 6,500 feet when doing the above air work I must then descend VFR to around 3,500 ft for approach control to begin factoring me into their flow patterns. This is a great time to couple my autopilot, review my approach and setup an initial coupled approach sequence. I always fly my first approach coupled to allow me the opportunity to look outside for traffic (since this flight is normally a solo experience) and refresh in my own mind gps, EFIS and autopilot buttonology. This first approach is usually an ILS since my gps is non-WAAS. I fly it to a T/G and then do a second ILS (non-coupled) with a go around accomplished at DH.
4. I then return to my home airport and finish my instrument work with a non-precision GPS approach. I like to fly to the IAF, do one procedure turn, and if that approach is coupled, I then dial in my step down altitudes to MDA. Again this is usually to a missed approach. Then to the visual pattern for two or three touch and go landings.
This routine normally consumes about an hour and a half of flying (give or take 15 minutes). I feel like it refreshes several important skills: checklist discipline, basic aircraft control, instrument procedures and equipment operation proficiency, and finally a little confidence in my airmanship skills, landings, and working with air traffic control.
Some will argue flying practice instrument approaches without a safety observer isn?t very smart (I cannot disagree here) but I?d rather risk myself (under approach control supervision) than ask someone else to join me when it?s been a while since I?ve flown. Besides single pilot operations are more the norm with me than multi pilot flight. With approach control calling out known traffic and ads-b in and out also providing traffic information I hopefully have minimized unknown traffic situations. However, ?see and avoid? is always paramount so that is why I?m always ?peeking? when flying instrument approaches (even in the rare situation of having an instructor/second pilot flying with me).
Hope this helps.
Many of the strips and glaciers we used to frequent were one way affairs. Some of them were also no go-around.
This would put us in situations where the winds were frequently less than ideal.
Were there limits to what we could handle going into situations less than ideal? Of course...many times we would just fly away and wait for a better day (or hour).
But some times...many times, we would land with a direct tail wind or a quartering tail wind. Waiting for ideal conditions wasn't really practical.
So practicing was, for me, the one way to keep my skills fresh. That way, when crunch time came, there was no doubt on what I could or couldn't handle.
As far as what a gusting quartering tail wind feels like...it felt like pure concentration...with your mind, hands and feet working overtime :D
Getting ready for some practice back in the day!
Resources
Hi Gary,
Here's a link to a quick reference "aircraft handling" card I keep in the in-flight guide in my airplane:
https://drive.google.com/file/d/0B8EIT6g2n8o_TzVwTUtLczB4WEk/view?usp=sharing
Over on the Safety page, there is a sticky at the top that contains a link to transition training resources. Appendix A has some information about maintaining personal proficiency, and Appendix B contains an example of a briefing guide covering just about anything you might consider doing during a training flight. If you download a PDF version via the link provided, the table of contents is hyperlinked to help navigate.
Drop me a PM with an email address if you'd like a Word version of either document that you can edit.
Fly safe,
Vac
I'm with Sam, I stay near the airport and practice in the pattern.
Good radio communications
Holding the same altitude with changing air speeds.
Watching the instruments for engine problems.
Watching for other aircraft.
Practice landings and take offs.
Then when comfortable leave the area and enjoy the beautiful view.
Cheers
TIA
Gary
Specific maneuvers not withstanding I use a single ?rust remover? maneuver. And that is slow flight. I fly the airplane at the stall, that is, as slow as I can make it go in unaccelerated flight. Then practice turns without losing any altitude. You know you?re good when you can play Rhapsody in Blue with your stall warning horn .
Based on the popularity of the "pattern diagram" threads, I'd say a good skill building exercise would be to get comfortable flying circuits with the Dynon off, and everything on the panel covered except oil pressure.
Some will argue flying practice instrument approaches without a safety observer isn?t very smart....
I know you put a lot of caveats on your post so this isn't to bash you. I also will do single pilot practice approaches but it's more to run through the equipment settings, make sure the CDI's work ect. I'm still looking out the windows and adjusting accordingly, I see nothing wrong with it as long as your not heads down longer than a 5-10 seconds. During VFR conditions don't every 100% relay on ATC to keep separation, especially in our little Class C OKC Airspace. The approach and departures for Will Rogers, Wiley and even Sundance come close to aligning with each other.
For the OP I run through PTS (Or whatever it's called now) about once a month. I know that out as well as the IFR equipment tests in less than an hour.
I like to do a few laps around the pattern, preferably somewhere no one is watching. Special attention to centerline alignment and touchdown point. I figure if I have to touch the throttle after I pull it to idle, I've done it wrong.
Slow flight and steep turns either on the way out or the way home, depending on how I'm feeling that day.
All of the above is good, but one thing a test pilot mentor taught me was:
"Life is too short to not land on the centerline. Every. Time."
A little vain? Sure.
But the ease at which that is achieved gives me a good data point on whether the rest of my skills are sharp enough.
Not recommended
8PkO9dqx9HM
Quartering TW or no, the pilot sat there rolling 3-point with the elevator completely neutral and didn't apply aft stick until after the "fatal" swerve left. Improper technique to begin with could have been made worse by wind conditions...or not. Don't know anything more about this one.
When you contemplate going flying - or are on your way to the airport, or about to crank up - after a long layoff, what worries you the most?
Landings? Well then take off, do some slow flight, shoot a bunch of landings in fairly benign conditions.
Or is it something else? Whatever it is, plan your training mission around that or maybe 1 or possibly 2 items more....your 2nd and 3rd worries.
But no matter what you decide to do, you can always factor in basic piloting skills in every part of the mission. For example going to and from the practice area:
maintain alt
maintain speed
maintain course
Exercise your checklist discipline.
Keep a good look out.
Exercise your instrument scan - make sure the engine et al is running ok.
I guess my point is that every phase of the mission provides opportunity for rust chipping.
Agree. My ?peeks? are more towards the panel and keeping the eyes outside - except on final where it?s closer to 50/50. I never fully trust ATC - been surprised too many times (retired military pilot).
