Old 10-02-2015, 06:54 AM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
In 2013 a local RV-6 tip-up guy made an off airport landing near here, and ended up on his back. The roll bar held up just fine and protected the pilot until help arrived and lifted the plane up to assist him with egress (he was about 80 and not terribly nimble.) Last I heard the airplane was bought by a well-known RV build outfit our west and was repaired.
As a tip-up builder/ flyer myself, I've studied this and thought long and hard about it. Bottom line is that I'm perfectly comfortable with the security provided by the tip-up roll bar. I think those who believe that the slider to be superior is this regard are deluding themselves, particularly when they think they can simply slide the canopy back in a rollover situation.
I also carry a small backpacking axe for emergency egress, and if push comes to shove, aluminum (tip-up) chops easier than 4130 (slider.)
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 10-02-2015, 09:22 AM
Originally Posted by curtis View Post
Most all of the reports I have ever read ALL RVs (tailwheel or nose wheel) that land off airport will end up on their back.
I agree.
The main wheels on a tail dragger are even further back than the nose wheel on a trigear (closer to the C.G.)
If the ground is soft or there is vegetation tall enough to grab the gear, going over is highly likely.
Scott McDaniels
Hubbard, Oregon
Old 10-02-2015, 10:31 AM
Snowflake's Avatar
While this is true, the main gear on a TD also deflects up and back when compressed, offering compliance and energy absorbtion while not tending to "dig in". The nosegear on a NW deflects back and down, digging further into the ground.
So as soon as a nosewheel comes down on rough/soft/uneven ground, it's going to be digging in, while on a tailwheel aircraft you will likely bleed off some speed decelerating before anything really grabs.
Of course, everything will depend on the stackup of a lot of factors in any off-airport situation... The third wheel placement will only be one of those factors, and I believe the TW has a slight edge in that regard.
Rob Prior
Old 10-02-2015, 10:51 AM
rdoerr01 rdoerr01 is offline
Default You can read about N369RV.
I built N369RV which was a RV-9A Tip-Up and I had an off-field landing the resulted in a flip over. The roll bar sure helped, but it is a little lower than the high point on the canopy which did help when you impact the ground. I was knocked out for a few minutes and had to be put in a brace until the x-rays came back. I had a very stiff neck for 2 months and it still bothers me on occasion today, which is 11 years later. The canopy did break but it was only around the top where your head is. I could see that at the time but pounding on the sides of the glass would not break it. It wasn't until I realized it was broke over my head which is now in the ground that I started breaking it piece my piece up to the side rail until I had a big enough area to crawl out of. All this time the most horrible part is the smell of gas. Even with the fuel valve off, I had mostly full tanks and it will just gravity flow out of the vent lines in the RV-7/9 fuse the way it's designed.
Ray
Old 10-02-2015, 11:02 AM
Analyze it all you want Rob, but accident evidence shows that a tail dragger or trigear RV landing in the conditions that existed for this recent accident, the end result is generally the same....
Scott McDaniels
Hubbard, Oregon
Old 10-02-2015, 11:41 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
In my forced landing in a plowed field with my 6A, I luckily flared a bit too late, lacking the prop wash over the elevator and hit level at about 60 knots which immediately sheared the nose gear leg upper bolt and folded the leg flat with the cowling. We simply slid along the ground for 150 feet on the flattened gear leg/ tire/ cowling (turned 90 degrees to lie flat against the cowling bottom). We didn't flip.
The main legs were splayed a good 20 degrees outward from a 7G vertical impact according to the G meter.
There are lots of possibilities here but generally if you land in a plowed field with an A model and try to hold off, the gear will slowly fold back on the first impact and you'll flip. Probably the same for a non- A given the position of the gear. The anti-splat stuff won't make any difference in a rough field landing since it's not strong enough to prevent the leg from folding and could even make things worse here.
Wiping the nose gear off like I did, could be an alternative strategy to not flipping even if it's against your natural reactions. Just food for thought.
The plane had almost no damage other than all 3 gear legs and a hole punched through the firewall and the battery box by the nose gear leg and of course all the wheel fairings and a brake rotor.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 427.8 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 10-02-2015, 01:16 PM
MarkW's Avatar
MarkW MarkW is offline
I had always hoped a water ditching would have the best outcome. Also thinking that whatever the landing surface, that I would be able to keep my TW right side up. After watching the midair/off airport landing on the beach in Italy I see how foolish my thinking was. I will avoid a ditching, even take trees before water and will always plan on being inverted when coming to a rest.
That video was an eye opener.
RV9 - N14MW - Flying
G3X - ECI Titan I0-320
Catto three blade prop
http://www.mykitlog.com/MarkW
Old 10-02-2015, 02:47 PM
bret's Avatar
bret bret is offline
My slider will have pull pins on the front rollers, if I'm going swimming, my canopy is going first!
2019 gladly supported
Old 10-02-2015, 03:01 PM
should it be standard practice to jettison the canopy at low speed if you have an off field landing? it seems it does more harm than good in the event of a flip over. probably need a set of safety glasses in place before jettison.
Old 10-02-2015, 03:27 PM
AndyRV7's Avatar
AndyRV7 AndyRV7 is offline
My takeaway from that video is to keep the canopy closed and land in deeper water. I think the worst water outcome would be to try to egress from an inverted plane with the canopy taking on water but held in place by the sea floor. I've always figured I would be outside the break anyway to keep from hitting swimmers or surfers. My plane is hangered at the beach so my local area is the shore.
If that pilot had braced for impact by wedging his hand against the roll bar, the canopy would have easily crush his hand or worse.
