Old 11-28-2012, 10:43 AM
Maj. Woody Maj. Woody is offline
Default Fitting in an RV-4
Hi Guys.
I am hoping to buy an RV-4 in the next few years and had a question regarding how I might fit in one. I am 5' 5" tall and 135 pounds. I imagine most pilots are a lot bigger than me. How do you think I will fit in an RV-4? Will I be able to reach the rudder pedals? Do most builders layout the distance of the seat and rudder pedals to fit their size or is this a universal dimension among Kit built RV's? Are the seats adjustable?
Thanks!
Dom
Old 11-28-2012, 10:45 AM
bkthomps bkthomps is offline
you'll fit just fine
Old 11-28-2012, 11:00 AM
ArlingtonRV ArlingtonRV is offline
I had the same concern, I am only 5' 7" and there appear to be alot of tall people out there. In my RV-12 I had to slouch down in the seat to get the rudder pedals all the way to the stops. I just bought an RV-4 in September and it fits like a glove, literally. I don't think you'll have a problem. If anything it would be the other way around and tall people would have teeth marks on their knees all the time.
Steve Rush
Arlington, WA
ArlingtonRV on YouTube
RV-8 (Bought Flying)
Glasair Sportsman (Sold)
RV-8 Tail, QB Fuselage (Sold)
RV-4 (Bought Flying) (Sold)
RV-9 Tail
RV-12 120018 Flying (Sold)
RV-7 Tail, Wings, Started Fuse (Sold)
Old 11-28-2012, 01:06 PM
Thanks for the info guys. A nice gentleman let me sit in his RV-4 last year at Oshkosh but I was so excited that I did not pay much attention to the ergonomics.
Dom
Old 11-28-2012, 01:44 PM
JDRhodes JDRhodes is offline
In all RV's rudder pedals and seats are adjustable to fit the pilots. If it's your airplane, you'll be able to set it up to fit you comfortably.
Jeff Rhodes - Taylorsville, GA
RV-9, 7 - going fast
BC-12D - going slow
jrhodes@v1salesmgt.com
Old 11-28-2012, 02:03 PM
Sid Lambert Sid Lambert is offline
I guess that could be true depending on how you define 'adjustable'.
The RV-4 would require you to rebuild the seat pan and add a bracket to the seat back in order to adjust the seat position forward. You would need to put shorter rudder cables in to move the pedals closer to you.
If I needed to sit taller and closer in a -4 I would have the seat bottom and back reupholstered adding a layer of high density foam. This goes a long way in comfort and is easy.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 11-28-2012, 03:55 PM
southtarnation's Avatar
southtarnation southtarnation is offline
The plane was designed for you.
Im 5'10, 135. And it fits great. I could even stand to move the seat back to straighten my legs more. Also there are rudder pedel extensions if you find you need them.
Jesse
'89 RV-4, N2626C - purchased flying
Converted to Fastback - Sliding Canopy - Tall Gear
Dynon Skyview w/ acc. & VP-x Sport
Catto 3-Blade (gen. 1)
Based: KPGD
Old 11-28-2012, 04:25 PM
AWESOME.
Thanks!
Dom
Old 11-28-2012, 06:16 PM
n82rb's Avatar
n82rb n82rb is offline
you don't need new rudder cables to adjust the pedals. you just have to make four new straps that attach the cables to the rudder pedals. there is a few inches of adjustment just by lengthening or shortening the straps.
bob burns
N82RB
Old 11-29-2012, 01:47 AM
WAM120RV WAM120RV is offline
Default Seats
Oregon aero will make seats that allow you to fit in the aeroplane. I had mine made for people in the 5'08 range. The only down side to thicker seat padding is that it will put the stick in your groin, and the panel a bit in your face.
The seats are really comfortable though!!
http://www.aerobuilder.blogspot.com
Steve Arnold
England
In completion stage of Loehle P5151
Built and now Flying G.BVLR Vans RV4
Rebuilt G.BDBD Tailwind
Rebuilt G BVTN Kitfox
Built G CDCD RV9A with WAM120
Riveted wings on Glastar G.LEZZ Now (G. SKUA)
