Old 09-23-2016, 07:47 AM
8 ball 8 ball is offline
Default Setting prop pitch
Where may I obtain an instrument to set my prop pitch in tenths of a degree? Can someone help me?
Old 09-23-2016, 08:07 AM
Rick RV-4 Rick RV-4 is offline
Default Maybe this?
I have a digital level (from Sears) which shows any angle in tenth of a degree increments. Would something like that work?
Old 09-23-2016, 08:16 AM
I Believe it just might work I will look at a picture of it on Sears website thank you very much have a great weekend
Old 09-23-2016, 08:22 AM
DHeal DHeal is offline
Get a digital level (I use a Sears version) and build a bracket (mine is made of scrap aluminum) that can be temporarily attached to the prop blade to hold the digital level. Be sure to position the bracket/level on each blade in the same relative location to facilitate the blade pitch comparison. There is much discussion regarding this matter in the VAF/RV-12 blog.
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 750+ hours (as of Apr 2019)!
VAF donation through June 2019.
Old 09-23-2016, 08:27 AM
Old 09-23-2016, 03:57 PM
Load "Clinometer" app on your iPhone ~ $2. Accurate to 0.1 degree.
See... https://play.google.com/store/apps/d...inometer&hl=en
Hinckley, Ohio (1OA2)
EAA #499867
RV-12 Bought Flying Oct 2015 with 48TT - Hobbs now 421
LSRM-A Certificate 2016
Special Thanks... EJ Trucks - Crew Chief A-4 Skyhawks
and MJ Stricker (my flight instructor) - 1st Lt./Captain B-17H WWII
Old 09-23-2016, 04:31 PM
jcaplins's Avatar
jcaplins jcaplins is offline
I use my iphone and the free Stanely level app:
https://itunes.apple.com/us/app/stan...565961826?mt=8
I just make sure I position the phone on the same part of the blade for each measurement and each blade is moved to the same position for each measurement. Of coarse, this is a relative measurement to make sure each blade is the same pitch, not the absolute pitch of the prop.
....and I'm off to the airport to re-mount and adjust my prop right now.
Jeff Caplins
California
RV7 N76CX
(started: Feb 2002 --> Completed: May 2016)
