Echo Tango
How plausible is this? I realize you can throw stuff behind the seats with the canopy open, but it would be nice to load from the side, too. Just something I've been thinking about. Finishing up my Emp. kit.
The inside lower portion of the baggage area is double walled, plus the rudder cable is in the way. So a very small door about 8" x 8"
then there is a reinforced vertical stretcher, then another 8" x 11" opening is available, just above the longeron. Pretty small openings thouogh.
I would keep in mind that it is a monocoque structure so the shell is important in overall strength. If you do put in a door I would make sure you have it fully engineered and keep all the paperwork mainly for resale. Its going to through up flags in a pre buy.
George
