FlyEFII Throttle body type
N360DF
Member
Folks, anyone who can tell be the brand/type the flyefii using?
Or anyone with one on the shelf who can supply photos and measurements ?
I'm an early adopter of Robert's EFII system. The throttle body I have is a Summit Racing part # SUM 227203. I tried looking it up on their website but I can't find it. Going by memory it is a 60MM bore--which is a little large for my 320. Robert may have a different supplier now.
Thanks for the info... I planning go with EFII. But I want to find the throttle body so I can make a 3D model and start create airbox/filter/cable etc.
I read some place he use BBK 80mm ?
Best regards
I used an airbox from a 1987 Nissan Stanza for my 9A. I modified the air intake to work by having an aluminum tube welded to a plate that bolts in place of the original elbow.
Just received my engine a few weeks ago.
EFII set up and has a BBK 65mm.
Just now starting to try to figure out how to connect the air box.
Really could use some intel on how to rig this air box.
Lloyd
