Bob_pipedream
Hi all,
Am planning to make my elevator tip closeouts now. the bits where the elvator tips have the huge opening that needs blocking...
Was thinking of using expanding foam (in the can). Then when cured, cutting it back to give a recess of about 3-5mm and then using epoxy filler to make the smooth surface.
How does that sound? My thought is that epoxy is compatible with expanding foam and will not melt it?
All good fun these final stages...
