Hornet2008
Hi all
I'm half way through attaching the wing tips using piano hinges. The method I'm using calls for a blue foam rib glassed into the wing tip about one and half inches to two inches inside with epoxy. I have the blue foam, however, it is too small in height to fit. Is there a way to successfully join the foam to do the job. Is there another material I could use? Complete novice at f/g.
