Chadmeyer24
I recently purchased an rv4 and it is unpainted yet with around 500hrs on it and the left aileron has a small crease in it so I'd like to replace the aileron or just possibly reskin it. My question is I read someone mention that you can buy prebuilt rv8 ailerons which are the same as the rv4's, is this true?
If not am I better off saving everything other then the skin or should I build an entirely new aileron. Also I'd like to put electric trim on it if that makes any difference.
Also while I'm at it durning my inspection I found one very small crack around a rivet (as many people find on rv4s with .016 skins) on the top of the left elevator. Being that I want to paint it I'm thinking I better replace or rebuild the elevator or else that crack will just ruin the paint, am I right? The right elevator seems to be perfect so do I replace both with .020 or just the left with another .016. (Engine is 0360 with 2 blade c/s if that makes a difference). Seems crazy to replace the whole thing just cause that one tiny tiny little crack but think I have no choice before paint.
Let me know your guys feelings and insights on these two topics..
Also if anyone has an aileron or elevator that they wanna sell let me know!
