Old 01-24-2018, 04:53 PM
merlin3 merlin3 is offline
I think tru trac includes it with their purchase. I thought I read somewhere that someone tried to buy it from them and they wanted like $200 because they don't like selling it seperate or something. Was hoping there was another source for it.
Justin
Rv-6, o360, whirlwind cs prop, old paint and panel
Rv-4,o-320,prince prop, mgl avionics screens - sold
Old 01-25-2018, 06:34 AM
SJordan SJordan is offline
This is correct. I called them and they wanted $200+ if I could not prove I had there servo. The Dynon -6 bracket works great except you donít get a clamp.
Shawn Jordan
KDVT
RV4. N11XZ
2018 dues paid.
Old 01-25-2018, 07:27 AM
blackbeard10's Avatar
blackbeard10 blackbeard10 is offline
Default clamp for roll servo
I used the clamp that Trutrak provides. If I were in your shoes, I would get some 4130 sheet that is the same thickness as their clamp and make your own clamp.
Have someone or yourself weld the ear on that attaches to the servo. I think the ear is a little bit thicker steel. The weld is a simple tig weld.
Mark Wyss
Mark Wyss
Cincinnati
RV4
0 360 A1A Ellison throttle body
PMags
Trutrak Efis
Catto 3 Blade
FLYING
Old 01-25-2018, 09:27 AM
I did something very similar to what Vern did. This puts the servo in the bay forward of the main spar. Having the servo there makes it much easier to maintain and repair. Over the years, 12, I have had to replace my roll servo three times. The heavier roll forces of the EVO wing may have had an influence on that issue. The "tab" does not have to be on the bottom of the tube, mine is on the top. The point is to measure the distance from the tube to the hole in the supplied bracket and then make sure that your tab is the same distance away, be it on the top or the bottom of the tube. Check that the range of movement is such that you never get into a position where you can go "over centre" . This check should be done however you mount any of your servos.
CPL & IFR rated
EVO F1 Rocket 1000 hours,
RV14 Tail dragger
Fairlea Field
fairleafield@gmail.com
Old 01-25-2018, 10:27 AM
I've got a Navaid servo mounted forward of the spar & the link attaches just behind the pilot stick on top of the walking beam. I copied someone else's installation when I did mine. Happy to email you some pics; I no l no longer waste time linking them here.
Charlie
