Old 01-23-2018, 07:58 PM
merlin3 merlin3 is offline
Default autopilot install
I am installing mgl autopilot servos in my rv4. I have looked threw all the threads on autopilot install but cannot find one simple thing. Is there somewhere I can order the clamp that people use for the roll servo that clamps onto the push tube in between pilot and passenger stick? I used the dynon install kit for the pitch servo and that worked perfect but looking for best way to install/attach roll servo. thanks.
Justin
Rv-6, o360, whirlwind cs prop, old paint and panel
Rv-4,o-320,prince prop, mgl avionics screens - sold
Old 01-24-2018, 07:07 AM
Scott Hersha Scott Hersha is offline
My (former) RV4 has a GRT roll servo mounted as you describe - under the floor, connect to the roll tube. GRT sells a servo mounting kit for this on their website: www.grtavionics.com.
SH
RV-8
Cincinnati, OH/KHAO
Old 01-24-2018, 07:12 AM
vlittle's Avatar
vlittle vlittle is offline
Or just fabricate a control horn:
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 under construction
Old 01-24-2018, 07:21 AM
Vlittle i think i saw that picture but wasnt sure how it worked as it didnt seem like it would rotate properly. I was really looking for the roll tube clamp as that seems the easiest way.
Justin
Old 01-24-2018, 07:41 AM
SJordan SJordan is offline
I ran into the same problem a few months back with my roll servo and just cut a tab out of 4130 and tig welded it on the bottom of the control tube betweeen the seats. Works great but a pain for sure. A nice clamp on tab would be great but sourcing it got tough. Good luck.
Shawn Jordan
KDVT
RV4. N11XZ
2018 dues paid.
Old 01-24-2018, 02:56 PM
Whitman Whitman is offline
Isn't it this?
Dynon 100866-000
RV6 Roll Bracket
https://www.dynonavionics.com/includ...ions_Rev_F.pdf
Whit
RV-4, #audiaviator
"Poise under pressure is the single most valuable thing you can have as a pilot. Make mistakes, take corrective action as quickly and calmly as possible and press on."
Old 01-24-2018, 04:06 PM
that is the mounting bracket but does not include the attachment to the control tube. I ended up making something similar to vlittle so we will see how this works out.
Justin
Old 01-24-2018, 04:15 PM
Larco Larco is online now
Or this https://cdn.shopify.com/s/files/1/21...92066230149458
Old 01-24-2018, 04:21 PM
I have that mount but it still doesn't help because they don't give you that clamp with the mount. that was the problem.
Justin
Old 01-24-2018, 04:45 PM
IT is the same clamp used on the RV8. When I installed the TRU TRAC roll servo on an 8 the clamp at that time was part of the kit. Maybe Try Trac will sell you the part? https://cdn.shopify.com/s/files/1/21...61252192108417
