Old 02-11-2018, 02:37 AM
Pittsartist Pittsartist is offline
Wrap some gorilla tape around your fingers glue outwards, put it on the canopy adhesive and wait a second or two then quickly pull it off.
No solvents and no scratches from rubbing - worked superbly for me
Bit like hair waxing ......
Old 02-11-2018, 03:32 AM
madhun madhun is offline
I’m not about to try it without checking with the manufacturer first, but I wonder if eucalyptus oil would affect acrylic; nothing better at removing gum glues.
Quentin Carter
Bushby Mustang II - 170hrs and counting
$500, if Mrs. Hun ever asks aircraft parts are $500!
Old 02-11-2018, 07:22 AM
Scott Hersha Scott Hersha is offline
I drove up to Dayton, Ohio area to pick up a new canopy for my RV8 after cracking the original one during construction. The guys at Airplane Plastics (manufacturers of our Vans canopies) cleaned glue residue off my new canopy with isopropyl rubbing alcohol - like you get at Walgreens. They said they use that stuff by the case. I've used it and it works fine. Washing with water and mild detergent (like dawn) after the alcohol is a good idea.
SH
RV-8
Cincinnati, OH/KHAO
Old 02-24-2018, 10:58 AM
Turbo69bird Turbo69bird is offline
Just an FYI during my vinyl wrap iused isopropyl alcohol to clean the very edge of the canopy the the vinyl could over lap the edge onto the acrylic a tiny bit. It did not harm the acrylic a all.
Saw an A&P Destroy a Cessna window with brake clean one day on another field though so wouldn’t recommend trying that one.
Proud owner of 925RV
Special Thanks to Fred Stucklen
While I'm not a builder if I happen to give advice , I will not be responsible for damage to equipment, your ego, parts, world wide power outages, spontaneously generated black holes, planetary disruptions, or personal injury that may result from the use of this advice.
Old 02-24-2018, 11:18 AM
az_gila's Avatar
az_gila az_gila is offline
Smile
As other have said, "mineral spirits" and "naptha" are sort of generic names and you don't exactly know what's in the bottle.
At least a bottle of isopropyl rubbing alcohol from the drug store/supermarket is clearly marked to be only one ingredient and water.
It was my favorite for removing many years of masking tape a plastic protector off my -6A canopy during construction.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 02-24-2018, 11:27 AM
climberrn climberrn is offline
Default Wrong cleaner
On another note, I grabbed the aerosol can of plexi cleaner to clean the canopy prior to a flight recently. Sprayed over a large area and started to wipe it off. It just left oily streaks, and would not come off! Looked closer at the can, and it was actually “stainless steel polish” for the tool box😳😱😤. I grabbed the can out of habit, but someone must have moved them. Grabbed ALL the clean towels I could find and got it off, with a lot of swearing. No apparent damage a few months later, but all the aircraft cleaning products are in a totally different area from the rest of the shop chemicals. Got lucky this time!!
Joel
N626JA
RV-7A at CXP
Flying!
