Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 03-26-2020, 09:33 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Default Garmin GPS175/GNC355/GNX375 Software Available For Download
We are happy to announce that we are making software updates for the 2” series of certified IFR navigators (GPS 175, GNC 355, and GNX 375) available in our EAB Software Download Area. The software can be downloaded directly from our website to an 8 GB SD card and loaded into any unit installed in a non-certified aircraft.
Anyone wanting to update the software for these units will want to first download Service Bulletin 2048 and review the software update process. After reviewing the service bulletin, download the software loader image, and create a software loader card for the update. There is only one software download, which includes the files required to update all 3 units listed above. The current download link will update the Main System Software to 3.10.
Please feel free to send any questions or concerns our way at G3Xpert@Garmin.com.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 03-26-2020, 12:41 PM
KPmarc KPmarc is offline
No Mac support? Really??
Marc Cook, Editor in Chief
KITPLANES Magazine
Old 03-26-2020, 02:17 PM
RV8JD's Avatar
RV8JD RV8JD is offline
KITPLANES Magazine
Maybe a comment in the next issue of Kitplanes will get Garmin's attention!
Carl N.
Arlington, WA (KAWO)
RV-8, 675 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel Standard Libelle 201B - Sold
Rolladen-Schneider LS1-f - No longer owned
Old 03-26-2020, 03:22 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Much like asking FF "What's wrong with Andriod that you don't support it?"
Carlos in Arizona
EAA Chapter 538 President, www.538.eaachapter.org
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 03-26-2020, 03:58 PM
jamesrw2002 jamesrw2002 is offline
Is there a change log? What are the changes?
Justin
James Walsh
VAF Staph since 98
RV-4 based at 52F
G550 Based at VHHH
... or LGB.. or ZHHH... or wherever they tell me to put the thing.
Proudly paid the donation!
USN OEF/OIF Vet
Old 03-27-2020, 08:02 AM
g3xpert's Avatar
Hi James,
The change log is listed in the Service Bulletin Document, but I have included below. The 2" Navigator series software was newly added to the support page in order to make available to the experimental market similar to the GTN series.
GPS 175/GNX 375/GNC 355 Main Software Version 3.10 contains the following changes:
• Adds support for additional FIS-B weather products:
◦ Turbulence
◦ Icing
◦ G-AIRMET
◦ Cloud Tops
◦ Lightning
◦ Center Weather Advisories
• Updates NEXRAD “No Coverage” overlay to be semi-transparent
• Adds support for database SYNC for transferring databases between Garmin displays – transfer
and receive from any GI 275, GPS 175, GNX 375, or GNC 355 and receive only from G500 TXi/
G600 TXi
• Improves availability for advisory guidance on LNAV approaches in areas without SBAS coverage
• Fixes a problem where GAE 12 calibration was limited to 6 points
• Adds Altitude Source Input Configuration setting to GPS 175 and GNC 355 to prevent nuisance
messages when connected to Sandel 3308/3500/4500
• Fixes an issue with GNC 355 carrier squelch setting. It is now applied when the value is changed
• Adds GI 275 support
• Adds Remote Radio Control Format 1 for GNC 355
• ARINC 429 labels are transmitted when in config mode
Great to see your panel project turn out beautifully!
BR,
Brad
Garmin G3X Support
g3xpert@garmin.com
Old 03-27-2020, 11:31 AM
Hello Brad,
Thanks for that! It's my first update and at first glance, I couldn't find the service bulletin.
I am so in love with this panel! Keep up the stellar work guys!
Hi James,
◦ Turbulence
◦ Icing
◦ G-AIRMET
◦ Cloud Tops
◦ Lightning
G600 TXi
BR,
Brad
James Walsh
VAF Staph since 98
RV-4 based at 52F
G550 Based at VHHH
USN OEF/OIF Vet
Old 03-27-2020, 12:31 PM
g3xpert's Avatar
Default Service Bulletin
Originally Posted by jamesrw2002 View Post
Hello Brad,
James,
There are two links in the software download area that begin with GPS175/GNC355/GNX375. One of them is the Service Bulletin Document, and the other is the software download itself.
Justin
Garmin G3X Support
g3xpert@garmin.com
Old 03-27-2020, 09:00 PM
I found it immediately after Brad pointed it out. The error of my ways!
Thanks Justin, hope you guys are staying safe and healthy!!
James,
Justin
James Walsh
VAF Staph since 98
RV-4 based at 52F
G550 Based at VHHH
USN OEF/OIF Vet
Old 03-28-2020, 03:23 PM
gblanck gblanck is offline
Default changes from older versions?
The service bulletin describes changes from v3.03 to v3.1. A unit we just updated hadn't been updated since it was installed and had v2.02. Are there change logs for releases between older versions available online anywhere?
-Greg
Greg Blanck
RV-8 Completed March 2014
Redwood City, CA
RV-8 Build Log
