Old 03-23-2020, 10:38 AM
mike newall's Avatar
mike newall mike newall is offline
Default Fuselage Build Trolley
When we built our 8, we had a low wooden trolley on castors to support the QB fuselage so I could work 'into' it early on.
Anyone done one for a 10 as the forward body gets assembled ?
If so, got any snaps please ?
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2019
Old 03-23-2020, 10:43 AM
Show Planes had one when they did the 10.
There used to be photos of it on their website while the build was going on. Cant find the photos now------but maybe an email would get them sent to you??
As I recall, it was a rectangular frame with adjustable height risers that picked up the spars, and the step sockets. Casters to make it roll around easy.
Old 03-23-2020, 10:49 AM
I made a wooden one like Mike described. I used blocks on the trolley rails to level it fore and aft. The fuselage was supported on the spar stubs and on the ends of a pipe inserted through the sockets for the steps.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-23-2020, 11:14 AM
Zuldarin's Avatar
Zuldarin Zuldarin is offline
Here is the one I have been using. If you make one just be sure you have access to insert the gear legs such that it doesn't require cutting the stand apart to get it out. :-)
I padded the front and rear crossbars before I lowered the fuse onto the cart.
Darin
Snoqualmie WA
RV-9A Flying as of 03/2015
RV-10 Building - Finishing Kit
www.DarinAnderson.com
2020 donation sent!
Old 03-23-2020, 12:29 PM
Spot on Chaps !
Donated in 2019
Old 03-23-2020, 06:56 PM
Richard Connell Richard Connell is offline
another example
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
Old 03-24-2020, 04:38 AM
cderk cderk is offline
I made one just like the one Tim Olson made, and it worked out great. Keeps the plane low enough that i was able to climb in and out without needing a ladder
https://www.myrv10.com/tips/workarea.html
RV10 - #41673 ready for inspection!
http://n688cd.wordpress.com
Old 03-24-2020, 06:47 AM
leok leok is offline
Default A different solution
I made a short set of 'legs' for mine with a castor on the bottom. Bolted on with hardware store bolts (that I also used for the initial wing fit up).
I made up a small sled for the rear of the fuselage. Notice the spacing of the two supports is right under a bulkhead
Building started Oct 5th 2014, Flying since 1/16/2020
http://www.mykitlog.com/leok
RV Hotel, come by and visit if you're in town
Dues paid 2020
Old 03-24-2020, 07:08 AM
rvanstory's Avatar
rvanstory rvanstory is offline
Built my dolly from wooden saw horses from Lowes and furniture dollies from Harbor Freight.
Randy Vanstory
Building RV10
N783V - Reserved
Flying Mooney M20J
Tail Cone, Wings, Cabin top, Doors, Windows done. Engine hung, Prop & Spinner installed, Cowling fitted, Wheel Pants and Gear Leg Fairings done, Avionics delivered but waiting to be installed, Seats are being upholstered..... Itís beginning to feel like a plane.
Donation Happily Made 2020
Old 03-24-2020, 07:20 PM
wjb's Avatar
wjb wjb is offline
I built two. The first is a VAF published design, relatively easy to find
This second one is a bit lower and worked very well. Solid and stable, and a good hight to lean over the rails and work with both feet on the ground.
Hacked it together with some Van's crate leftovers and some 2x4's. The under area made for very convenient storage location for cabin panels, seat backs, etc.
It's a bit surprising how much wood I used given that it's an all aluminum airplane
Bill Bencze
N430WB RV-7 #74152, tip-up; IO-360; CS. Pushing toward first flight in 2020!
Log at: http://rv7.wbencze.com
Defeating gravity one rivet at a time
VAF 2020 donation happily made
