I have exactly what you describe. I have Airflow Systems A/C and dual Dynon ADAHRs.
I have the ADAHRS mounted under the fiberglass cross shelf on the opposite side of the A/C blower. I have never seen an interference issue between the two. Turning the A/C on or off results in no change in the heading reference. The only time I ever saw the heading swing from interference was when the cable of the rear seat shoulder strap sagged down to within an inch or so of the ADAHRS which is why I mounted then to the bottom of the shelf (right side up of course) instead of on top. I was trying to maximize distance between the blower motor, the battery, and the ADAHRS pucks while still staying in the prescribed zone for the magnetometer. The external magnetometer option wasn't available at the time of my build and I probably would have used it at the time but haven't seen the need now.
I thought at one time to replace the cables with stainless steel from a sailboat rigger, but haven't had any issues in the current configuration. I always make sure that the shoulder straps are secured taut and not sagging down close to the shelf.
Airborne compass calibration went fine. No compass issues at al in over 200 hours. I have likely over 100 hours with A/C running as we use it much more than we thought we would.
I have listed in my ops specs and limitations that the A/C is to be off in IMC, but that was more to please the DAR. I don't think it is necessary. In today's GPS nav world, compass accuracy just isn't as vital as it was in the dead reckoning days of yore. When it comes right down to it, the biggest asset today from a perfect compass reading is accurate wind display on the EFIS. Otherwise, you're still going to navigate by the GPS track regardless.
