Avionics harnesses
Stein Air
Stein Air. They are an advertiser here.
Good technical advice. Fast availability by phone. No BS in the sales. And zero defects products.
651-460-6955
[email protected]
Bona fides: I've been an intermittent customer since 2006.
Approach Faststack is another with great reputation.
Their product is good for an initial installation of a multi-unit system. Not sure I'd recommend them for adding on one unit to an existing system, unless they sell cables that do not have the hub connector at the other end.
Stein
There is a reason why Stein is so busy. If you want your harness done right call them.
Anyone have a person or shop they can recommend to make a Kx155 harness. Thanks!
The hardest part of wiring the KX-155 is finding the molex pins. After that, it's actually pretty trivial, especially given that you're going to need to plug the other ends of the wires into various things yourself anyway.
Just a thought in case the usual suspects are too backed up...
I had my schematics done by stein air and I did the harness myself, best thing I ever done.
