Old 01-16-2018, 12:18 PM
unitink72 unitink72 is offline
Default Wire terminations
Originally Posted by rv6ejguy View Post
One thing I'm not too keen on is people using vinyl clad crimp connectors in aircraft. They don't offer great strain relief. I prefer non-insulated ones, solder or crimp and then slide a long piece of double wall, glue infused heat shrink over the joint. Time consuming and a PITA to do in many locations and cases but WAY better strain relief, corrosion protection and retention qualities. See the photos below:
Brought this out from another thread. This makes a lot of sense to me. Where do you get these terminals, and the heat shrink tube? Do you need a different crimper than the one usually used for PIDG terminals?
Josh T
RV-10 #1750
N67SC reserved
http://n67sc.blogspot.com/
2018 Dues Paid
Old 01-16-2018, 12:43 PM
WingsOnWheels WingsOnWheels is offline
The PIDC terminals have proven to be very reliable, particularly over soldered terminals. There is not really a need to use the uninsulated terminals and heat-shrink. And don't solder them unless you know what you are doing, otherwise you will be far worse off.
Thant said, you can get the heat-shrink at Frys, Harbor freight, online, lots of places. For the terminals, order quality parts from an electronics vendor like digikey, mouser, stein, ACS.
Colin P.
RV-6A #20603: Emp done,Wings done, Fuselage done, Electrical done, FWF about done, Canopy done, Fiberglass/Finishing in work. Getting very close!
PP SEL / A&P
N616CG (Reserved)
I donate every year on my B-Day (in Dec)
Old 01-16-2018, 01:47 PM
Minor correction; it's PIDG, not PIDC.
http://www.te.com/usa-en/products/te...?tab=pgp-story
The real PIDG has nylon insulation, which I believe is higher temp than vinyl. But firewall back, that really isn't an issue. (To head off the naysayers, *ALL* wire insulations omit noxious gasses if they get hot enough. Fuses/breakers prevent the wire overheating, and if the fire's already there and big enough to ignite wire insulation, you've got more pressing issues than wire insulation.)
Be aware that 'one and done' crimpers are not symmetrical; there's only one proper way to insert the terminal (though it will fit either way). Properly oriented, the insulation grip area gets slightly less crimp than the wire.
As others have said, solder and crimp are equally effective if done properly, and both need strain relief. PIDG has it built in; the bare terminals must have something added, whether crimped or soldered. Crimps were designed for production, where any meat sack is forced to make a proper crimp to get the tool off the work, and get it done fast. Solder takes a bit more skill & time, but costs a lot less money.
"You pays your money and you takes your choice."
Old 01-16-2018, 02:01 PM
Raymo's Avatar
Raymo Raymo is offline
I've been using and very happy with this heat shrink available online at reasonable cost. It is heavy duty and seals the connection. Getting it back off, on the other hand, is not so easy, which is means it seals very well.
You can get cheap stuff that is very thin (think HF) but you'll have to double it up, IMO.
Get it black or read and various sizes. Comes in 4' lengths.
I like AMP connectors/terminals for most jobs.
Ray
O-360-A4M w/ Catto 3 blade NLE, AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter,
PlanePower Alt, FlightLines Interior, James cowl & plenum
All lines by TSFlightLines
NSDQ
Old 01-16-2018, 07:17 PM
johnbright's Avatar
johnbright johnbright is offline
Default Anatomy of a Good Solderless Terminal Connection - AeroElectric Connectio
https://www.google.com/url?sa=t&sour...D2op80L8Ap1xJb
John Bright, RV-6A 25088, at FWF
O-360, 8.5:1, vert sump, SDSEFI EM-5
Z-14 adapted for EFI, wiring and IP CAD files here
Newport News, Va
Old 01-16-2018, 07:18 PM
johnbright's Avatar
Default Bob's Shop Notes: Chevy vs. Cadillac Crimp Tools
http://www.aeroelectric.com/articles...rimptools.html
Newport News, Va
Old 01-16-2018, 07:30 PM
pczar3's Avatar
pczar3 pczar3 is offline
Default Was taught not to solder...
The reason was when soldering the solder will wick a small way up the wire and cause a rigid connection. The aviation grade wire has multiple strands for flexibility. Of course those were F4 Phantoms I was working on.
Paul
Paul
N694BP reserved
RV-6A Very Slow Build!
Old 01-16-2018, 07:42 PM
Sigh...
We were taught to not go lean of peak on Lycs, too.
Look at that pic of the crimped connector before the shrink wrap is applied. Think there's no stress riser there?
Attachment method matters not. What does matter is supporting the wire beyond the stress riser point.
Sorry, but this solder/crimp thing just seems to be a bigger thing than primer wars, sometimes.
Charlie
No Holiday Inns recently, but a couple of past lives as an electronics tech.
Old 01-17-2018, 06:17 AM
Walt's Avatar
Walt Walt is offline
I agree that there is nothing wrong with a properly soldered, heat-shrinked and supported wire.
However, I can make a good solid crimped connection in about 2 seconds vs about 2 minutes or more to do a solder connection. If I was wiring your aircraft and getting paid by the hour which method would you want me to use
I'm pretty sure crimp connections were invented so the production world could save time.
EXP Aircraft Services LLC
RV7A built 2004, 1700+ hrs
Old 01-17-2018, 06:25 AM
Walt,
I agree. Please look back at what I wrote in post #3. I guess I should have completed the sentence with 'for parts and tools.'
