Old 04-03-2017, 08:11 PM
Abbygirl1 Abbygirl1 is offline
Default flap position indicator
Just wondering if anyone has marked their flaps for position visible from the cockpit. Would like to do something non-electric. Just maybe markings on the aileron or something. Wings are white and I thought I could mark them somehow.
Help?
Dad of an Air Force C-17 flight instructor 2018 dues paid... plus some.
Old 04-03-2017, 08:12 PM
blueflyer's Avatar
blueflyer blueflyer is offline
A thin strip of black electrical tape at 10, 20 30, etc, degrees has worked for me in the past
Old 04-03-2017, 08:45 PM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Here's what I did: (had a decal made by the local graphics shop)
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Helped build Bob Lund's airplane)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 04-04-2017, 12:48 AM
Turbo69bird Turbo69bird is offline
I used a angle finder and a China (grease) pencil in red to mark the line, figuring maybe I'd get used to the position and remove it later. It's fairly faint yet easy enough for me to see from the cockpit, Has helped me a lot since I'm pretty low time in the six.
Proud owner of 925RV
Special Thanks to Fred Stucklen
While I'm not a builder if I happen to give advice , I will not be responsible for damage to equipment, your ego, parts, world wide power outages, spontaneously generated black holes, planetary disruptions, or personal injury that may result from the use of this advice.
Old 04-04-2017, 07:44 AM
Veetail88's Avatar
Veetail88 Veetail88 is offline
I didn't mark them an don't really see a reason to. In the pattern I don't really want to focus on some little mark to determine flap position. Time and sound suffice.
At the perch, reduce throttle and lower flaps for a count of 3 and a quick glance at the flaps to see the position. You'll be able to tell if they're a third deployed without marks. Turn base, another count of 3 and another glance. Turn final and lower the flaps until I can hear the flap motor sound change indicating full deployment. Nuthin to it.
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
Old 04-04-2017, 07:56 AM
n816kc n816kc is offline
Default mark and count
I marked mine with grease pencil early on to develop consistency in transitioning to and operating my -6. Almost 7 years later the marks are still there (I may have touched them up once, not sure), but a 3 count puts the flap right on the mark. I rarely look anymore unless setting up for a shortfield takeoff and then it's only to check the aileron to flap alignment at full deflection. No harm in having the marks there.
Kevin Crews
Bartow, FL
RV-6 'Woo hoo!'
2018 =VAF= donor
Old 04-04-2017, 09:16 AM
Schooner69 Schooner69 is offline
Used an "angle-ometer" to determine 1/2 flap, guntape to denote same.
Airborne check to ascertain "count" required to acquire 1/2 flap position.
Subsequent iterations achieved by "counting", quick check of flap "indicator" to confirm.
J
Old 04-05-2017, 11:42 AM
6 Gun 6 Gun is offline
Default Flaps
All or none
Bob
Old 04-05-2017, 03:14 PM
snopercod's Avatar
Default Sharpie!
That's exactly what I did. I used a Sharpie on the aileron. Also, my AFS Sport AoA annunciates "FLAPS" when they're almost fully deployed.
(2018 dues paid)
Old 04-07-2017, 11:28 AM
664781 664781 is offline
Default Take Off
I put a piece of tape at the 10 deg. point for short field take-offs. All landings are full flaps.
Kurt Lohmueller A&P
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
