The instructions don?t seem to say to do this, but the aft fuselage side skins overlap the bottom center skin and typically it seems that such an arrangement would require the edge that overlaps to be broken slightly. What is the consensus on doing this?
Thanks. I must have inhaled too many fumes from using the soldering iron to remove the blue film from the rivet lines of all the skins last night, as I know I had read that note before but I didn't see it when I actually got excited about clecoing the skin into place.
Called Vans today and they said even though the instructions don't say to, putting a break along the lower edge and the short vertical edge at the front makes for a nicer overlap.
Juliette
