Old 04-15-2018, 09:52 PM
Blain's Avatar
Blain Blain is offline
Kent, do you plan on Sikaflex? Excuse me if you stated it earlier in the thread.
Blain
R-22 sold.
RV-8 AW Cert 02-09-17
N82 Sierra Tango
Avatar courtesy of AircraftStickers.com!
Dues gladly paid thru Nov. 2018(my reminder)
Old 04-16-2018, 10:06 AM
kentlik's Avatar
kentlik kentlik is offline
Haven't decided Blain. I just ordered the rivets to drill and rivet, but not sure I will do this method but wanted the option. Leaning on drilling per plans. I try to follow plans most of the time. Have left over sika? I have a source for some locally that I need to get in touch with the owner about buying. I want to have it on hand to back up the rivets regardless.
Kentlik
RV-7A in progress
http://www.imdb.com/name/nm0527486/?
Private pilot, ASEL!
EAA 105 Chapter 7S3
financial contributor
"The credit belongs to the man who is actually in the arena..." Teddy Roosevelt
Old 04-19-2018, 10:28 AM
kentlik's Avatar
Default canopy latch
This latch stud is not in the correct orientation to the latch arm...
I will have to bend the latch arm to get proper purchase on the stud. I am aware that I need to massage the end of the latch arm I have that math to do next.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 04-19-2018, 06:55 PM
jcarne's Avatar
jcarne jcarne is offline
I'm starting to see why most build logs have an absurd amount of time under the canopy section. Keep fighting the good fight!
Jereme Carne
PPL
RV-7A Emp. coming along
Working on Wings
Exempt but gladly paying!
Old 04-20-2018, 07:27 AM
kentlik's Avatar
Default Latch
Here is the properly bent latch arm:
Here is the clearance of the frame with respect to the aft deck:
It finally came together, I need just to finalize the finished latch position.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 04-20-2018, 05:42 PM
kentlik's Avatar
I test fit the side skirts and the back of the canopy is still too wide! I am crying on the inside right now....the skirts are supposed to be up against the side skin I would imagine correct?
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 04-20-2018, 11:56 PM
Lars Lars is offline
Mmmm... fiberglass/carbon.... makes for a perfect fit...
Lars Pedersen
Davis, CA
RV-7 Flying as of June 24, 2012
600 hours as of April 9, 2018
Old 04-21-2018, 09:19 AM
kentlik's Avatar
Aaarrrgghh...Not that I don't like to do layups, I don't, but more work, more time.
Thanks Lars!
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 04-21-2018, 12:38 PM
kentlik's Avatar
Default Big guns coming in
Got out the big boy per Lars advice and it is infinitely easier to compress. Now, strangely enough, I have an uneven distribution of the compression. I watched it like a hawk and still got it. Whats more is my twist is back! HAhaha, incredible...so, sticking with what I have for compression in the back and going to get the twist back out after I get the front compressed down. The big ratchet strap made it super easy.
This is with varying degrees of compression:
I have a new setup for the twist removal, a bit more clean and refined, sorta.
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
Old 04-21-2018, 01:44 PM
kentlik's Avatar
So I am done for today. Period. If I work on this any longer I know myself, I will end up with a bunch of little pieces laying on the floor and the gas ax hanging from the tree in my front yard...
Kentlik
RV-7A in progress
EAA 105 Chapter 7S3
