bellcrank jig device
dent
Member
I just got a 4 project and do not have any pictures of information on the bellcrank jig device.
Any help would be appreciated.
Dennis
There is no bellcrank jig for the RV-4.
The drawings have a dimension detail showing what the neutral position is.
In the "old days" ...
we just set up the "call out" posit in the drawings and then drilled a #41 hole through the bellcrank support bracket and the bellcrank and used an .089" dia hinge pin section to connect them when needed. I always drilled mine so they would be accessible through the inspection cover later - if ever needed after the aircraft was flying.
David Howe
