Old 08-15-2018, 06:11 PM
flyvansrv7 flyvansrv7 is offline
Originally Posted by DeltaRomeo View Post
Has anyone in the RV world built a DIY lifting floor creeper? Something like the guy here, but with a twist. There are a few threads about people buying lifting creepers, but I was specifically looking for a DIY, made with 2 X 4's and bolts type thing. Workbench like...
My little mod idea: I would like to have a boat winch type setup on the right side just about where my hand would rest. This so I can crank it while laying down to lift the creeper bed slightly. I don't see why the crank assembly couldn't stick up a little bit to accommodate a standard winch/handle. Something like the Photoshopped Frankenstein here that I hobbled together.
You know how you need different heights when you're wiping the leading vs trailing edges of your taildragger RV? And the bottom of the cowl vs the underside of the HS? Trying to address those things using the RV Community Brain Trust.....and wood.
Something like Sam did with his DIY tail lift project, but laid down over on its side. Absolutely if I can work up some plans and a prototype with the help of others, I'll host the parts list and plans here somewhere if nobody else wants to.
Something like this, drawn up on my iPad just now:
(Rope in red)
I’d like to start at the ailerons and move back and forth, then with a half turn of the crank be perfectly positioned to do the center of the wing, then with a half turn of the crank be in perfect position for the leading edge area. That sort of thing.
Maybe a little cup holder on the side for a spray bottle and rags...
https://ezcreeper.com/
[ed. $950. Thanks I'll pass. b,d]
Old 08-15-2018, 06:17 PM
f14av8r's Avatar
f14av8r f14av8r is offline
Default Love the idea - Hate the Price
This is a great idea but the price puts it in the purely luxury category. I can put a lot of pillows under my head with my $29 Harbor Freight creeper for the $400 price of the EZCreeper! Frankly, the price gives me the CREEPS!
[ed. The EZ is $950 - no thanks I'll pass. I could build 15 of what I'm proposing for that <g>.....probably more! b,d]
Randy King
Tampa (Wimauma), Florida
RV-4 N212CS (sold)
RV-8 N184RK (flying)
Flying an A320 to pay the bills
Exempt and gladly donating anyway - Current through March 2020
Old 08-15-2018, 06:47 PM
Scott Hersha Scott Hersha is offline
Just bought the HF creeper today for $27 and turned it around to give me a little more Ďaltitudeí, and I have to say, itís pretty comfortable. I donít think the plastic wheels will last long, but Iíve saved better castoring wheels from other projects and Iíll change them out when it becomes necessary. Designing and building a home grown version could not be done cheaper.
SH
RV6/2001 built/sold 2005
RV8 Fastback/2008 built/sold 2015
RV4/bought 2016/sold/2017
RV8/2018 built/Flying
Cincinnati, OH/KHAO
JAN2019
Old 08-16-2018, 07:18 AM
DennisRhodes DennisRhodes is offline
DR, why not use a low priced hydraulic jack from HF to do the lifting job. Most will operate from the horizontal position and you could have a large lifting force. Maybe more than the the frame allowed if not careful. Most floor jacks have a horizontal mounting for the cylinder with linkage to the jack plate.
DRRhodes
2019 VAF dues paid
RV9 N908DR
Old 08-24-2018, 09:06 AM
Ralph Ketter Ralph Ketter is offline
This is definitely not made out of wood,
nor is it a DIY lifting creeper but,
I came across this called the Human Hoist power shop chair.
I found their website here:http://www.humanhoist.com/human-hoist
No price is shown but I know it's way more than I would ever consider.
Ralph Ketter
La Luz, NM
RV-6 Flying
Old 08-24-2018, 12:05 PM
Wow! I'll bet that one will exceed my weekly airplane budget money for several months. I bet it does DR's also. But nice looking piece of mechanical equipment and appears well made.
DRRhodes
2019 VAF dues paid
RV9 N908DR
Old 08-24-2018, 12:23 PM
F1Boss's Avatar
F1Boss F1Boss is online now
Default electric linear actuators
This one has 100lbs/force on 12v. I think a drill battery would work fine with an up/down switch (like the flaps switch in your RV). Less expensive models are available from plenty of suppliers. This part could make the "X" in the lifting mechanism fold and unfold nicely...all you have to do is build the X frame, figure out how much travel you need from the actuator, and your dang near done with the job!
https://www.progressiveautomations.c...-actuator-ip66
Some less expensive options:
https://www.northerntool.com/shop/to...tric-actuators
Switches and fittings at Northern Tool too..
Best,
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
Old 08-24-2018, 02:27 PM
I was looking at the HF creeper on line and wonder if it's possible to mount the seat and backrest on a separate frame that's hinged at the foot and raised and lowered by a cheap HF jack. That would give you a height adjustment and also a back angle adjustment, but not a foot-height adjustment.
If you added a foot rest for use when the seat is raised (and thus inclined) then it might not be a bad way to do this.
Old 08-27-2018, 11:24 AM
vfrazier's Avatar
vfrazier vfrazier is offline
Put a cushy backrest on this and keep rocking......
https://www.harborfreight.com/500-lb...art-60730.html
[ed. Awesome!!!! dr]
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold
