Old 03-27-2018, 11:50 AM
smokyray's Avatar
smokyray smokyray is offline
Default If you must...
Vlad you madman!
Here is a great link to vacuum system installation and associated plumbing. However, to quote my Dad when I was in HS about delivering a date to her home late:
"I wouldn't advise this".
Having been an A&P most of my adult life and had to repair/troubleshoot vacuum systems, I grit my teeth at the prospect of owning and flying one.
Like you, I have flown many different complex aircraft including military and civilian Jets with complex systems, the overall question is why borrow trouble? More than anything for me, the pump and hardware rob you of around 3HP. It's all about the ponies...
Simplicity is a virtue but if you must: https://www.experimentalaircraft.inf...yro-system.php
До скорого!
Smokey
Old 04-30-2018, 05:49 AM
noelf noelf is offline
Vlad, I have sent you several PM's over the past week. Although I hit "send", my post are not showing up in the note string.
I am in the area and have the instruments that we talked about if you still want them. I will have free time starting Wednesday, 5 May.
Noel
RV-6A N6NF
tip-up
flying
Old 04-30-2018, 07:39 AM
Roger that Noel! I am on the go too and online comms are interrupted. Will catch you at KVAY please keep that pump.
Old 05-27-2018, 08:55 PM
RV8Squaz's Avatar
RV8Squaz RV8Squaz is offline
http://www.tempestplus.com/Portals/0...0%20100110.pdf
http://www.rapcoinc.com/pdf/Informat...%20Drawing.pdf
Jerry Esquenazi
RV-8 N84JE
