Old 12-31-2015, 12:21 PM
f1rocket's Avatar
f1rocket f1rocket is offline
Default Different Fuel Tank - Questions for You
Well, it's winter time, the condition inspection is done, and I'm looking for a project. I am giving some thought to building an alternative fuel tank for the -12. I am just getting ready to dive into the engineering and CAD/CAM aspects of this, but before I do, I have a few questions for those of you smarter than me. First, let me say that I'm not convinced of either the need or the feasibility of doing this. This is more of a mind exercise at this point to see if something better might be possible.
First, my design thoughts. I'd like a tank that fits over the spar, behind the seats, and frees up baggage space. I guess the driving force behind this change is to get more room in the baggage area. While I can make the current limited space work, it's not altogether convenient and it is downright impossible for anything longer that a couple of feet. Capacity is also an issue. I would love to get 5 more gallons on board for those times when I fly by myself cross country. I fully admit this change, if made, appears to have marginal benefits. Like I said, I'm just looking at this at this point.
My initial concern is with the center of gravity shift forward of the weight of the fuel. Today, I fly mostly in the forward regions of the CG envelope. In fact, I find it impossible to get anywhere near the aft CG limit due to my weight, and the typical weight of any passenger. Moving the fuel CG forward is going to make this problem worse. I suspect, and will need to prove this once the engineering drawings are done, is that I will be forward of the forward limit at takeoff at gross weight.
So my question to those who have worked on this on the -12 before (both alternate tank design and wet wing design) is where did you calculate your fuel CG to be with your design? Do you have issues with the CG forward limit? Did you have to make other changes, like move the battery or add weight, to get the CG back in range?
If, and it's a big if, I can create a plug in tank to replace the current tank and not have to reengineer a bunch of other changes, then it might be worth putting together both kits and completed tanks for sale. I have free access on the weekends to an advanced machine shop so my primary investment is raw materials and time.
Comments and suggestions welcome.
Randy Pflanzer
Martinsville, IN (II87)
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 12-31-2015, 01:21 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
Having just built a new tank using the sending unit and float guage from the old tank..... Not a huge fan of the multitude of proseal and rivets. I realize that even wing tanks use rivets and sealant to hold them together, but the -12 tank has a lot of pop rivets holding it together. If it's something you don't do every day, it can be a process..... Messy. I like the welded designs that have been presented in another thread, but my guess is it's pricey. All custom work from a machine shop. I don't mind where the tank is located or how it is attached. Perhaps a poly tank of the same shape? Even viable wing tank option that keeps the fuel near the wing root..... Unlike the Viking option with the tubes that extend to the tip, that worries me with CG and loading effects on the wing (spin testing anyone?). We only remove wings for the condition, so a "quick disconnect" setup or even standard AN fittings at the wing root would work. I'm not an aeronautical engineer but I do believe there is always more than 1 way to solve a problem. I'm sure vans did a lot of work on the standard tank and it's the way it is for many reasons. Not demeaning their engineers or testing process, as the current tank does serve its function well, but I think it could be improved upon.
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 435 Hrs on the Hobbs
Old 12-31-2015, 01:47 PM
skydiverlv skydiverlv is offline
Joe Gores behind seat tank.
http://www.vansairforce.com/communit...t=tank+channel
Larry Vandegrift
ULPower 260is
Old 12-31-2015, 02:20 PM
f1rocket's Avatar
Thanks for the link. I knew someone had built a behind-the-seats tank, just couldn't remember who. Joe did a nice job.
I see from Joe's pictures and thread that the new tank did not increase the capacity AND my worst fears about moving the CG forward are real. If I use Joe's calculation of 100" aft datum for the tank, at full fuel and two passengers without baggage, the airplane ends up outside the forward CG limit after burning approximately 8 gallons. That won't work for me anyway.
I guess I could look at a flat tank that goes across the floor of the baggage area. I'll have to chew on that one for awhile. Time to think out of the box.
Randy Pflanzer
Paid through 2043!
Old 12-31-2015, 02:48 PM
TomVal's Avatar
TomVal TomVal is offline
Talking
With a flat tank design I would be interested how that design would affect minimum fuel quantity for takeoff or go-around and also consideration should be given to minimum fuel quantities for various degrees of bank. It would be a most interesting tank baffle and fuel pickup design to cover those variables.
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 12-31-2015, 03:58 PM
Michael White's Avatar
Michael White Michael White is offline
Randy,
That was my first thought...a fuel tank that would go all the way across (as well as fore & aft) of the baggage compartment. Vary the height during the design process to give you the capacity you want. Making it fit the full size of the baggage compartment should keep the fuel CG pretty close to stock (as opposed to moving it forward). The tank bottom would slope down (following the fuselage profile) to put the "sump" up front near the spar...minimal unusable fuel. The only big downside would be that the fuel tank top is now the floor of your baggage area...perhaps thicker material to prevent punctures would take care of that issue?
Good luck with your ruminating. Let us know what you settle on.
Moose
VAF #136
N424LZ Reserved
Old 12-31-2015, 04:48 PM
DaleB's Avatar
DaleB DaleB is offline
I agree that a fuel tank covering the entire width of the baggage floor would be nice... except you'd have to pull the tank during the annual inspection to get access to the tunnel. Careful design of the baffling and a suitable top skin thickness could take care of sloshing, slips with low fuel, baggage weight, etc. You'd probably want to build it with full height internal ribs, maybe with some little hinged one-way flappers similar to what's used in the RV-7 tank with a flop tube.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 12-31-2015, 07:19 PM
Bill_H's Avatar
Bill_H Bill_H is offline
For 5 more gallons, this is a VERY effective mod, well designed, easily removable, in the sticky "Mods" thread.
http://www.vansairforce.com/communit...=64145&page=24
Old 12-31-2015, 11:09 PM
Mich48041 Mich48041 is online now
Randy, I am out of town right now without access to my drawings. Send me a private message with your email address and I will send you what I have when I get home. About CG, consider how far forward the CG moves in a stock RV-12 when Van's tank is near empty. As long as your planned tank does not move the CG more forward than that, it should be OK. I also have an Excel spreadsheet to calculate the CG with my tank.
Joe Gores
RV-12 Flying
Old 01-01-2016, 01:32 PM
f1rocket's Avatar
Thanks Joe.
Randy Pflanzer
Paid through 2043!
