Old 05-24-2018, 04:02 PM
lucky333's Avatar
lucky333 lucky333 is offline
Default FS: RV7A Project
RV7-A #71875 w/finish kit
Flat kit professionally built to past QuickBuild stage - all airframe metal essentially done. First rate workmanship. Ready for your choice of avionics and engine.
Fuel plumbing routed.
Brake plumbing routed to flex hose points.
Wing tip lenses cut and fitted.
Gear legs on casters to move around shop.
Wings / Empennage surfaces on storage rack on casters w/bottom storage.
Finish Kit:
Slider
Fuel Injection Cowling
Dynafocal 1 mount
Sensinich FP Spinner
2ed Gen Nose Wheel Geometry
Upgrades:
Grove 56-1A Main Wheels w/ Goodyear Flight Custom II main tires
Grove 56-1 Brakes - over twice the kinetic capacity as standard Van's
Grove 671-1x Master Cylinders (4) w/adjustable pedal rake
Andair fuel valve
Andair gascolater
Van's Options:
Co-Pilot Pedals
Electric trim - elevator and aileron
Baffle kit for Lycoming (I)O360 180 HP
VA-168 transducer manifold
Tie Down Rings
Map Box
Baggage Tie Downs
Strobe/ELT mounting kit
Primary electrics: master and starter solenoid, switch, bus and wire.
Odessey PC-680 battery
Battery Box for Odessey PC-680 battery
Float Fuel senders
Lots of extra AN nuts, screws, washers etc. to drop on floor and not worry about.
Clecos
Lots of Heyco bushings in various sizes for wires, etc.
Located in Dallas, TX. We have moved to smaller digs in Houston and she needs a new home.
$26.9K/offer
John Oldenkamp
rv7a71875 at g m ai l . com (all lower case, no spaces)
Phone: EightOneSeven Five2Eight ThreeOneSevenSeven
Pics upon request.
John Oldenkamp
RV-7A project for sale
VAF Paid 2018
