Old 12-13-2015, 11:10 PM
N710B N710B is offline
Default RV-6 Engine change
Hi all,
I'm new to the group and just purchased an RV-6 with an O-320E2D. I plan to change it to an O-360 fixed pitch and am curious as to some of the details of what I will need to change. Is it the same engine mount/baffling? Differences in accessories? What model O-360 works best? Thanks in advance.
Dave
Old 12-14-2015, 12:05 AM
Ralph Inkster Ralph Inkster is offline
Engine is 1.5" wider. Carb & filter assembly hang down about 1" lower. So cowling may have to be changed out or modified. A new 360 baffle kit is easier than trying to rework the 320 to fit. Exhaust may have to be modified or changed out. Spinner will have to be reworked or changed out. Air filter could be modified to work, but Vans has a filter box kit for the 360 engine. Starter & alternator should be interchangeable if both engines are same vintage. I would assume you would get proper mags with the new engine.
Above is assuming you are talking 180hp O-360 parallel valve and not a 200hp IO-360 angle valve which basically means replace everything.
Ralph
Maintain lots, upgraded - repaired - & modified more, rebuild a few, & built some too.
Old 12-14-2015, 12:06 AM
PCHunt PCHunt is offline
Popcorn time! .........
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2018 Donation Plus, Gladly Sent
Old 12-14-2015, 06:00 AM
Michael White's Avatar
Michael White Michael White is offline
Originally Posted by N710B View Post
Hi all,
Dave
Dave,
Welcome to VAF!
Unless the 320 has a hole in the case (or something else physically wrong with it), fly it the way it is for a while. The 320 is a fine engine, and might surprise you with the amount of performance it gives the 6. It also will go well past TBO time with normal care and regular oil changes. If you're just looking for more get-up-and-go, try a constant speed prop first. You'll get more performance for less money (and hassle) than a complete engine swap.
(Is it just me, or is the popcorn extra tasty this morning? )
Moose
VAF #136
N424LZ Reserved
Old 12-14-2015, 06:07 AM
FLY6 FLY6 is offline
Default o-320 E2D
Unless I have been misled, the E2D is a solid crank so it can't be converted to a constant speed.
Al Grant
Flying RV6, O-320
Stoney Creek, On
Dues Paid
Old 12-14-2015, 07:38 AM
Thanks for the responses. That is what I was afraid of. Someone mentioned that it shouldn't be a difficult change, but kinda thought that might not be the case. I bought it with a timed out engine, planning on overhauling it when it started going downhill. From the sounds of it I'll just go with the high compression pistons. I'm really happy with the performance in every aspect, other than takeoff from a higher elevation grass strip. Guess I could switch from the cruise prop as well.
Old 12-14-2015, 07:52 AM
The Titan stroker crank is a ~$4k option to add 20 hp to an O-320. Might be worth considering if you're looking for more power.
Kyle Boatright
Atlanta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 12-14-2015, 07:55 AM
Sam Buchanan's Avatar
been here awhile
My E2D has a hollow crank but the case isn't machined for a governor.
If your engine is still 150hp, a change to the 160 cylinders will provide a nice boost. Leaving the prop as-is will give you a climb prop. A 160 with a 150 prop is an excellent climber and still has pretty good cruise performance.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 12-14-2015, 08:15 AM
mosquito's Avatar
mosquito mosquito is offline
Default O-340
A 'stroker' O-340 with the Titan crankshaft should be a direct replacement for your O-320, same size and weight, but with O-360 power (180hp). That's what I intend to replace my O-320 with one day (hopefully in the very, very distant future).
-jon
RV-6 | O-320 | Triple-bladed Catto
Old 12-14-2015, 08:53 AM
eisnerrv4 eisnerrv4 is offline
Thumbs up O320
I have an O320 E2D 150 hp in my RV-4. I have owned my RV-4 since 2009 an my engine works like a top; knock on wood.
Unless you really have to, I'd run the O320.
Just my opinion of course. Whatever you decide hope it works out for you.
Brian Eisner
RV-4 C-GRJT
Bedford Nova Scotia
Canada
Dues paid for 2018
