swisseagle
Hello,
I know, many times asked here, but no precise answer ...
The Aeroquip aluminum fittings use this table: http://vansaircraft.com/pdf/Torque_Spec_Aluminum_Fittings.pdf
The aluminum tube to AN fitting use this table: AC 43.13-1B / TABLE 9-2. Tube data
But what the heck should I use on these, engine fuel pump fitting on the o-ring jam-nut:
Thank you for any input!
