I've read all the posts I could find, but still have one last question on the routing of the battery cable. I got it up to the gear tower. I am going to install a fuel injected engine, so I need both of the lower holes through the gear tower on the left side. What did you all do for the battery cable - - drill another hole? If so, where did you drill it and once through the back side of the gear tower, did you go all the way through or up and out one of the lightening holes prior to going forward to the firewall?
Personally, I think drilling a hole through the gear tower in its entirety, then past the fuel pump and up and through the firewall is the best routing. Thoughts?
Pictures would be a big help.
Northern VA
Dues paid
Northern VA
Dues paid
