I want to wire the Vans stall warner (Micro switch in the wing) to the comm. (Garmin GTR-200 - no audio panel). I see on the pinout that there is a AUX AUDIO IN HI and a AUX AUDIO IN LO. Do I wire the stall warner so that the signal is on the HI pin and then the ground (from the little circuit board) to the LO pin. Alternativey, could someone just explain what the HI and LO stand for. I am thinking it'll work if I wire the signal line to HI since the little circuit board is grounded and not run a ground from the circuit board to the radio.
Dave
Dave
