skyking902001
Need some wing tip advice from the collective brain trust. I wanted to stiffen the wing tips, but the law of unintended consequences bit me. Several mistakes--I used 3/8" dowel rod--1/4" would have been sufficient. Also used 2 layers of glass over the rods--1 layer would have been enough. And the real problem--I clamped the rods in while glue was drying and it left a depression on the outside of the tip. My question--should I just fill the depression with micro to regain shape or should I attempt to remove the dowel and try again. The pics show where the depression is on the exterior and approximate location on the inside. Thanks in advance.
