dbaflyer
I have the right wing tip hinges installed on the wing and tip. With it installed I have a noticeable up/down play which appears to be from the space between the hinge eyelets. The up/down play measured at the aft portion of the tip is 4-5 32nds.
Will this play become a problem when flying if allowed to work back and forth over time?
Will this play cause any issues with aligning the wing tip trailing edge with the neutral position of the aileron?
Has anyone else had this and been able to tighten up the hinge eyelets?
