Old 02-26-2018, 03:40 PM
Toobuilder's Avatar
Home Depot has some 3M stuff that is used for outdoor stair steps. It has a reflective strip in one side which is easily removed. I have it on my Rocket and it wears very well. When I repaint I'll probably go that way again.
About $6 IIRC.
Michael Robinson
______________
RV-8 - Flying
Old 02-26-2018, 05:04 PM
BillL BillL is offline
About $6 IIRC.
+1 3M also makes a type without the reflective strip. I have used it until it is time to paint. Looks good, works good too. It can be removed with a heat gun and residual cleaned with mineral spirits. [validated]
I'll probably use the Vans pieces with the model number after paint. I have them ready.
Bill
1st Flight 1-27-18
Phase II 8-3-18
Old 02-27-2018, 05:54 AM
MauleDriver's Avatar
MauleDriver MauleDriver is offline
Hereís what I did with some of the stick on material. Itís held up well for over 5 years and 1,000 hours. The pattern leaves the screws accessible, feet off the tanks, and no problem with the wing root covers.
https://www.dropbox.com/s/uth3vtbf3a...20AM.jpeg?dl=0
Old 02-28-2018, 08:46 AM
Greg Arehart's Avatar
Greg Arehart Greg Arehart is online now
Skateboard tape for almost 10 years, still looks new. I got mine free from the local shop because it was the end of a big roll and apparently not enough to do an entire board. Should come off fairly easily with some heat, but I've never tried (or needed) to remove it.
Greg Arehart
RV-9B (Big tires) Tipup @AJZ or CYSQ
N 7965A
Old 02-28-2018, 08:52 AM
Auburntsts's Avatar
My painter just added sand (or something similar) to some black PPG paint and painted my wing walks on. Works great. Prior to my paint job I used the Home Depot 3M tape on the wings and steps and it worked just fine too.
Todd Stovall
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
