Old 12-14-2017, 03:57 PM
nightflier nightflier is offline
Default Percent power vs RPM
Trying to establish percent power for POH for RV9A, with 160 HP Catto prop. ANy ideas?
Sam
Old 12-14-2017, 04:32 PM
moosepileit moosepileit is offline
http://www.vansairforce.com/communit...hp?t-8037.html searched for thread.
Searched for a Lyc image, I know the rpm is probably too low for a Catto.
RV-6 N91GG, bought from builder.
O-320, slider, carb, mags, FP
Old 12-14-2017, 04:55 PM
vlittle's Avatar
vlittle vlittle is offline
Sam
Search the forums "Engine Power Percentage?"
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 under construction
Old 12-14-2017, 05:10 PM
sirlegin's Avatar
sirlegin sirlegin is offline
Here's what I use in my 9A 160HP Catto 3 blade
POWER SETTING PERCENTAGE
RPM X 100 + MP (INCHES)
60=100%
57=95%
51=85%
48=75%
45=65%
42=60%
39=55%
36=50%
33=45%
30=40%
Nigel
RV9A-N113SQ
52F
Old 12-14-2017, 05:28 PM
RV8JD's Avatar
RV8JD RV8JD is offline
60=100%
57=95%
51=85%
48=75%
45=65%
42=60%
39=55%
36=50%
33=45%
30=40%
I think you meant RPM/100 + MP.
Example: 2450/100 + 23.5 = 48 is approximately 75% power.
Carl N.
Arlington, WA (KAWO)
RV-8, 280 Tach Hours
(Pic 1),(Pic 2)
(Pic)
Glasflügel H-201B Standard Libelle, N564NS - Sold
Old 12-14-2017, 05:55 PM
brad walton brad walton is offline
Originally saw the manifold pressure plus rpm formula from the RVator. But I doubt its accuracy. I can run 24/24 at low altitude burning 9 gph. I don't think I'm getting 75% power at less than 10.5 to 11 gph
Mine is an io 360
Last edited by brad walton : 12-14-2017 at 06:15 PM. Reason: Add text re displacement
Old 12-14-2017, 06:04 PM
RV8JD's Avatar
Note the Lycoming power chart in Post #2 above. At SL, 2400 RPM and 24" MP equals 75% power at approximately 10 GPH.
Note that the % Power approximation is not valid for LOP ops.
Carl N.
(Pic 1),(Pic 2)
(Pic)
Old 12-15-2017, 07:20 AM
Rupester Rupester is offline
The GRT EFIS installation manual just happens to have a MP-RPM-%power chart for an O-320. It's used to set up the EFIS for display of % power. I don't have access to my install manual at present, but I think you can access it at GRTs website under "documentation".
When I was doing the setup for mine, that was the best &clearest reference I found for % power. Further, when I checked it matched those mind-boggling Lyco graphs perfectly.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 12-15-2017, 12:15 PM
sirlegin's Avatar
I'm glad you were paying attention. Thanks
Nigel
RV9A-N113SQ
52F
Old 12-16-2017, 12:32 PM
Default O320 % power
Thanks for you help guys, VAF comes through again!
