Is there any limits on the life of aluminum brake lines? I've replaced the brake pads recently and inspected aluminum lines I rolled almost 8 years ago. It's my sixth set of braking pads for over 2K hours. I did nothing to the lines except inspecting them for cracks and leaks. There is a visible spot corrosion on them.
Should I roll new lines on my next condition inspection? How often do you replace the brake fluid?
