Old 09-15-2019, 08:19 AM
cduster cduster is offline
Default Curing a slow and hot Rocket: CHTs
I've recently picked up an early SN Harmon Rocket 2 and as is always the case, "new to me" airplanes always end up slower, thirstier, and hotter than the rest of the fleet. I'll be spending the next few months, or years, taking her from what she is, to what she should be. In order not to flood this thread with too many variables, I'll make multiple threads with known issues.
Currently CHTs are quite limiting and I think some of that may be instrumentation (MGL iEFIS), some is the poor baffle sealing, and some is the very limited exit area. I'm running down a bunch of possibilities in the instrumentation department, and we've spend a bunch of time and a few tubes of red RTV sealing up the obvious leaks. As for the cowling exit, the lower cowling is nearly flush with the bottom of the fuselage. I'll try and attach some pictures.
Are/were the factory HR2 cowlings nearly flush, or did they have something more similar to other RVs with a 4" or so deep "tunnel" to duct the air out?
Old 09-15-2019, 03:33 PM
Robb Robb is offline
which Rocket did you buy?
F1 EVO
Aviat Husky A1B
Old 09-15-2019, 05:09 PM
Gt-401 Gt-401 is offline
Default Exit area.
I have seen some rockets with larger inlets, but for most the stock size is big enough. Smoothing out the exit airflow seems to be very effective mine has a fairing on the firewall and motor mount to help the air turn the corner as it exits the cowling.
Old 09-15-2019, 05:18 PM
N86WR, SN 011 Its a beautiful plane that just needs a little TLC to bring her up to speed.
She had a large piece of flattened out hose clamped in between the exhaust stacks right about where the air exits the cowling. I removed that and trimmed a tiny bit of uneven material from the trailing edge of the lower cowling today. It will be tomorrow before I get any real numbers, but it sure seems to have helped a good bit. I'm guessing that the flattened hose represented about 9 square inches of obstructed exit area. Is there any need to tie the exhaust stacks together?
On another note, the LH upper landing gear intersection fairing has seen better days. It looks like a homeless place kicker used it for a shoe for the entire 2018 season. It really sticks out since its just about the only thing on the plane that isn't really nice. The crankcase vent exits flush with the belly at the left gear leg and I see where it is sucking oil all the way down the outboard side of the gear leg, so I'm guessing that it has the airflow really jacked up in that area. Does Mr. Harmon still supply these fairings?
All of the gear leg fairings are split in the rear to facilitate removal, but when installed, the gaps are unacceptably large. Are there any tricks to neatly pull them together?
https://doc-10-28-docs.googleusercon...c3x1x6R2CpGAEX
Old 09-15-2019, 05:49 PM
Did you cover and smooth the area around the lower engine mount cross bar? I'd love to see some pics of that if you have them available.
Old 09-16-2019, 04:41 PM
f1rocket's Avatar
f1rocket f1rocket is offline
The two most effective mods to improve cooling are to smooth out the top side of each inlet on the inside of the cowl and to add a plenum. There is plenty of air coming in, its just that too much of it is escaping.
It has been my experience that none of the outlet mods are needed once you redirect the inlet flow.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 09-16-2019, 06:34 PM
sailvi767 sailvi767 is offline
Come over to BQ1 for lunch tomorrow about noon and we can have two Rockets there! I am working on my temps also. Test flight to lunch for BBQ!
George
Old 09-16-2019, 08:07 PM
George
Durn, Id love to fly over there and check out your rocket, unfortunately Hurricane Dorian has us way behind at work. Maybe I can catch up with you some time in the near future. BQ1 is awesome by the way.
Old 09-17-2019, 12:53 PM
vfrazier's Avatar
vfrazier vfrazier is offline
What Randy said, plus the stuff on this page:
http://vincesrocket.com/Additions%20...2010-27-04.htm
Scroll down to the "Summer heating woes" section.
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 09-20-2019, 08:13 PM
Robertcropdust Robertcropdust is offline
Default Hr2
I was the second proud owner of 86wr. Private message sent.
Built and flying F1 rocket..2019
Built and sold RV8 fast back ..2017
Bought flying Hr2 and sold S#11 ..2014
