I bought an IO-540-C4B5 engine which had an inverted oil system installed in the past.
This is what is written in the logbook:
"This powerplant modified with a Christen 811-A sump kit. A Christen No. 805 sump plug has been installed in the front of the horizontal sump screen. This blocked the original oil entry to the pump. Oil return holes have been drilled in the rear case ref. Christen instructions Dwg. No. X-90064. The sump was modified per Dwg X-90062 with Christen 812-m weld bosses to receive the oil line fittings".
Please help me what all this mean and how I can get this engine back to standard configuration for use in RV10.
Thanks.
Johan
Thanks.
Johan
