Larry Parham
I just re-cut my plenum to match up to the cowl and added baffeling to the cowl for proper air flow from the cowl to plenum.. Also re-sealed all leaks of air. I do not have high oil or cly temps. Just wondering the relationship between the OUTSIDE AIR TEMP and AILTUDE.
Question
Day 1 at 8500 da OAT is 30 degrees oil temp is 170
It is not summer yet so what could I expect when temps go to
Day 2 at 8500 da OAT is 80 degrees. Assuming every thing is EQUAL what would you expect the OIL TEMP to be on day 2 ???
Question
